Home » Modeling » Papyrus » Extending the SysML Datamodel
Extending the SysML Datamodel [message #1059080] Thu, 16 May 2013 11:02 Go to next message
Hello everyone,
I would like to try to extend the data model of the internal block diagram, by extending the flow ports with some new properties. I would like to validate this properties with a custom validation approach.
I would like to use Papyrus for an approach I am investigating in my master's thesis for system validation.
I already search for this topic, but can not find any suggestion on how to start, especially because I am new to Papyrus and Eclipse Plugin development.
Thanks for any help.
Re: Extending the SysML Datamodel [message #1059184 is a reply to message #1059080] Fri, 17 May 2013 03:42 Go to previous message
Stefan S. wrote on Thu, 16 May 2013 11:02
Hello everyone,
There are probably some ways in which this can be done, but the simplest (not needing to create java plugin code manually) is to create a profile, and add some (OCL) validation rules to it (YMMV Smile. Search the forum for more info. Since this is a (very) recent feature (see [https://bugs.eclipse.org/bugs/show_bug.cgi?id=382975], I suggest you use at least the latest kepler milestone build.
HTH,
Klaas
Previous Topic:Critical Exception in latest M7 build
Next Topic:Initialize papyrus diagram from an UML file
Current Time: Wed Jul 23 23:01:10 EDT 2025
Powered by FUDForum. Page generated in 0.05364 seconds
