Menus under VE [message #105857] |
Thu, 08 September 2005 11:53  |
Originally posted by: davidyoung_2001.yahoo.co.uk
I have downloaded the 1.1.01 update to VE and I get the Menu palette.
When I try to drop a menubar onto a simple shell, it shows in the
JavaBeans view but doesn't appear on the "display" view and I can't drop
other men items onto the shell - what am I doing wrong?
Re: Menus under VE [message #106532 is a reply to message #106519] |
Tue, 13 September 2005 13:17  |
Ah, there was a cache problem. But it should of noticed that there were
new versions installed and wiped the cache. I may need to do some tests
to verify that.
xusong wrote:
> Now it works.See my steps in the following:
> --A: The complete new installation of Eclipse SDK&VE works fine.
> --B: If the previous version VE,like v1.1 ,has been installed, then you DELETE the org.eclipse.jem.beaninfo and org.eclipse.jem.ui directories beneath the .metadata of your workspace.
> Now you can have fun with the VE.
> Thank you guys in this discussion.
> XS
Rich Kulp
Re: Menus under VE [message #610713 is a reply to message #105857] |
Thu, 08 September 2005 13:57  |
It should appear in the Visual display once you have at least one menu
on it. Without any menus on a menubar the menubar is zero height.
But, the intent is that when working with the menu bar itself you work
with the java beans viewer instead. You drop menu/menuitems there once
you've dropped a menu bar.
Rich Kulp
Re: Menus under VE [message #610715 is a reply to message #105875] |
Thu, 08 September 2005 14:50  |
No I can get the menubar added, but no matter what I try to add after, it
won't let me either onto the display or the Java Beans view.......has
anyone else sucessfully downloaded and built a menu?
Re: Menus under VE [message #610717 is a reply to message #105857] |
Thu, 08 September 2005 14:56  |
If you have problems even using the JavaBeans view, try closing all
Visual Editor editors and then do a Project|Clean... On my installation
I was unable to drop an SWT MenuItem.SubMenu onto the menubar until I
did this.
Re: Menus under VE [message #610720 is a reply to message #105903] |
Thu, 08 September 2005 17:06  |
What did you select from the palette? Was it SubMenu?
Did you try to drop it on the menubar on the Java Beans View?
> it won't let me either onto the display or the Java Beans view.......has
Rich Kulp
Re: Menus under VE [message #610730 is a reply to message #105976] |
Mon, 12 September 2005 05:45  |
Originally posted by: javacard.hotmail.com
Actually closing the current .java file and open it again,the menu bar is visual in the display and Java Bean view.
The problem with my installation is:Even the menu bar is available,I still CANNOT add MenuItem.subItem.
any comments?
XS
Re: Menus under VE [message #610737 is a reply to message #106114] |
Mon, 12 September 2005 10:54  |
Do you get a "NOT" sign when you drag between the menu items on the java
beans viewer where you want to drop? What are your symptoms of cannot add?
> any comments?
> XS
Rich Kulp
Re: Menus under VE [message #610745 is a reply to message #106210] |
Mon, 12 September 2005 22:03  |
I try to drop a MenuItem.subItem onto the menuBar in the beans viewer or in the visual display,but the menubar shows the 'cancel' sign.No menu items would be added under the menubar in beans viewer.
Re: Menus under VE [message #610754 is a reply to message #106321] |
Tue, 13 September 2005 10:03  |
I'm stumped then. If everything is installed correctly it works for us.
Rich Kulp
Re: Menus under VE [message #610759 is a reply to message #106444] |
Tue, 13 September 2005 12:26  |
XS
Re: Menus under VE [message #610760 is a reply to message #106519] |
to verify that.
> XS
Rich Kulp
FUDForum. Page generated in 0.05942 seconds
