Help in analysis [message #1035069] |
Sat, 06 April 2013 05:10  |
Dear All,
I am new to this Memory Analyser tool. I am running a socket based application run the a database pooling and will various select and insert statements in it. Below is my results from the leak hunter.Suspect 2 I guess is due to nature I am pooling so the connection are alive all the time. I cant intepret well the suspect 1 as when I press the details it give a long list of following details.
java.lang.ref.Finalizer @ 0xf5e19670 40 92,688
next java.lang.ref.Finalizer @ 0xf5e1a6a8 40 93,024
next java.lang.ref.Finalizer @ 0xf5e1bda0 40 122,768
Suspect 1.
The class "java.lang.ref.Finalizer", loaded by "<system class loader>", occupies 1,337,176 (30.93%) bytes. The memory is accumulated in one instance of "java.lang.ref.Finalizer" loaded by "<system class loader>".
Keywords
Suspect 2
6 instances of "com.mysql.jdbc.JDBC4Connection", loaded by "sun.misc.Launcher$ExtClassLoader @ 0xf58bf000" occupy 432,624 (10.01%) bytes.
Biggest instances:
•com.mysql.jdbc.JDBC4Connection @ 0xf61c54f8 - 94,864 (2.19%) bytes.
•com.mysql.jdbc.JDBC4Connection @ 0xf61c4678 - 86,600 (2.00%) bytes.
•com.mysql.jdbc.JDBC4Connection @ 0xf61c4bf8 - 85,456 (1.98%) bytes.
•com.mysql.jdbc.JDBC4Connection @ 0xf626c348 - 68,000 (1.57%) bytes.
•com.mysql.jdbc.JDBC4Connection @ 0xf626c7d0 - 68,000 (1.57%) bytes.
Keywords
Re: Help in analysis [message #1059024 is a reply to message #1035069] |
Thu, 16 May 2013 05:30  |
Dear Andrew,
I have set my initial and maximum heap as 256Mb on a 8Gb machine. So when do you decide based on the heap size that it is a memory issue or problem. What size of the heap is an indicator of problem? Ok I got it about the finalizer is those where in the final statement rite. How about those link to classloader what is that indicates? What are the other feature of memory analyse can be useful to detect any type of problem?
FUDForum. Page generated in 0.04318 seconds
