QVT project organization [message #1058860] |
Wed, 15 May 2013 08:51  |
I was wondering what are the guidelines for managing complex projects in QVT.
In my project, I have a number of transformations each one with a bunch of mapping, query, helper operations. Should I create one file per transformation and put all the operation related to each transform in the corresponding file? Am I allowed (read: may be considered good practice) to create e.g. 4 files per transform, one for the main, one for all the mappings, the 3rd for queries and the last one for helpers?
How do you professionals manage your projects?
Matteo
Re: QVT project organization [message #1059297 is a reply to message #1058860] |
Wed, 15 May 2013 09:24   |
> QVT.
If your transformations are indeed complex and at same time independent
of each other, then you might even consider putting them into different
projects. As of now, the QVT builder does not keep compile artifacts or
a build hierarchy, so when you touch any one file it has no choice but
to rebuild all of them. Depending on the complexity of your files this
can become a major nuisance. My experience suggests to have as few
physical files as possible, since each additional file adds up in making
the compile process slower.
[Disclaimer: I am aware that this advice may well conflict with other
best practices and in fact I don't like giving it. But in my own project
I have now reached a point where I have had to permanently turn off the
QVT builder as it just eats to much resources.]
Marius
Re: QVT project organization [message #1059298 is a reply to message #1059297] |
Wed, 15 May 2013 10:56  |
I think that best practices are only starting to evolve as users get
more ambitious.
There are a number of Bugzillas regarding poor scalability of the QVTo
builder, some have been addressed recently and so Kepler should be better.
Unfortunately QVTo is not the only builder with suspicious enthusiasm. I
find other builders worse and disabling auto-build after any significant
GIT change very beneficial. Please raise a Bugzilla with clear deficient
scenarios.
Java encourages us to use deep wide package hierarchies.
EMF encourages us to use a simple model folder, and so perhaps just a
transforms folder. EMF JET templates have a bit more hierarchy.
IMHO the reuse of the Java layout by Acceleo is a good idea and will
evolve nicely when direct Java compilation materializes. So I encourage
you to try the Java src/x/y/z layout.
The OMG specifications define a Transformation as both a Package and a
Class and while packages can be nested the specifications tend to assume
that a Transformation is a root package, so you may need to push for
better tool support. For QVTr and QVTc and even OCL, I have been more
generous in the use of qualified names in the concrete syntax.
ed Willink
>> QVT.
> Regards
> Marius
FUDForum. Page generated in 0.06488 seconds
