Home » Archived » BIRT » Birt ODA 4.2.2
Birt ODA 4.2.2 [message #1058284] Mon, 13 May 2013 09:05 Go to next message
I would like to know how to migrate birt plugin version 2.6.1 to 4.2.2
Currently, I am able to create this latest version in my eclipse plugins and make a valid test. But I don't know how to generate the plugin for version 4.2.2 Birt Designer. In fact, I generate jar does not allow me to see the specific datasource that I created.
Re: Birt ODA 4.2.2 [message #1058449 is a reply to message #1058284] Tue, 14 May 2013 03:36 Go to previous messageGo to next message
Some details:
I followed this tutorial: www.ibm.com/developerworks/library/ba-birtextpoints/
that works very well. Now I want to use this plugin in a Birt Designer I download. How should I do?
Re: Birt ODA 4.2.2 [message #1058779 is a reply to message #1058449] Tue, 14 May 2013 23:41 Go to previous messageGo to next message
You should be able to drop the plug-in into your dropins folder in the BIRT download.
Re: Birt ODA 4.2.2 [message #1058847 is a reply to message #1058779] Wed, 15 May 2013 08:04 Go to previous messageGo to next message
Thanks for your answer.
But what do you mean when you say into your dropins folder ?
In Birt, I have a plugin folder but if I drop my jar file (my plugin) into this folder and after a restart of designer, my ODA didn't appear when I create a DataSource.
Re: Birt ODA 4.2.2 [message #1059137 is a reply to message #1058847] Thu, 16 May 2013 20:10 Go to previous messageGo to next message
The plugins folder should work too, but there should be a dropins folder there, too. I have one in my 4.2.2 install.
For your ODA, do you have a designer/UI plugin and a runtime plugin created?
Re: Birt ODA 4.2.2 [message #1059684 is a reply to message #1059137] Tue, 21 May 2013 04:20 Go to previous messageGo to next message
Yes, we have both plugin for designer and runtime.
I install birt in : birt-rcp-report-designer-4_2_2
and there is this folders : configuration, p2, plugins, and workspace.
I haven't dropins folder.
Re: Birt ODA 4.2.2 [message #1059877 is a reply to message #1059684] Wed, 22 May 2013 01:02 Go to previous messageGo to next message
Ah You're using the RCP. I didn't notice that before if you mentioned it. Like I said before, the plugins folder will work, too. Can you send me your plug-ins? If you cannot post them in here, you can email them to me. mwilliams at actuate dot com
Re: Birt ODA 4.2.2 [message #1061682 is a reply to message #1059877] Mon, 03 June 2013 09:29 Go to previous messageGo to next message
Hello michael i'm in vacation last week. Have you time to look file i send you?
regards
Re: Birt ODA 4.2.2 [message #1062489 is a reply to message #1061682] Sat, 08 June 2013 01:22 Go to previous messageGo to next message
Sorry for the delay in response. I was out of town at a conference this week and had other urgent items to handle last week. I'm doing my best to get caught up, now. It shouldn't be any later than Monday before I get a look at it. Hope you had a good vacation!
Re: Birt ODA 4.2.2 [message #1062833 is a reply to message #1062489] Mon, 10 June 2013 22:23 Go to previous messageGo to next message
I'm seeing the same as you. It's likely just from some sort of change in the newer version. Do you have all the code for the plug-in still, so you can try rebuilding and testing it with 4.2?
Re: Birt ODA 4.2.2 [message #1063555 is a reply to message #1062833] Thu, 13 June 2013 08:07 Go to previous messageGo to next message
Hello
I'm the author of this plugin.
I used Eclipse Juno 4.2 with BIRT plugin 4.2
For testing my plugin, i launch a RCP application from Eclipse (from overview tab of designer plugin.xml).
From there when I create a data source for my report I see my data source.
Then I used the Export Wizard to generate the jar., I copy it in the plugins directory of BIRT Designer. When I launch it and create a report, I do not see my data source.
Tank you for your help.
Regards.
Re: Birt ODA 4.2.2 [message #1064385 is a reply to message #1063555] Wed, 19 June 2013 00:47 Go to previous message
Any way you can send me the code? If you cannot post in here, can you send it to me at mwilliams at actuate?
Previous Topic:Change grid cells content dynamically
Next Topic:empty space between border top and text
Current Time: Wed Jul 23 18:08:49 EDT 2025
Powered by FUDForum. Page generated in 0.05386 seconds
