import gives strange error [message #1058827] |
Wed, 15 May 2013 05:59  |
I am using GUIdancer Version: 7.0.0.201303141638.
I migrated a test from V5 to V7.
Then I did an export.
When I import that xml again I get the following error:
The following Parameters could not be processed. Please correct the listed parameters before working any further on the project:
Are you sure you want to delete.*from the repository?.*
The full log is:
Connection to Database successful.
Importing projects...
Reading projects...
Reading project file /Users/tom/Test_1.0.xml.
Project "Test" in version 1.0 requires the following project(s):
- project "unbound_modules_swt" in version 7.0
- project "unbound_modules_concrete" in version 7.0
- project "unbound_modules_rcp" in version 7.0
Finished reading projects.
Importing Test_1.0...
Finished importing Test_1.0.
Finished importing projects.
I have no clue what is wrong or what I should do. Any hints?
The test seems to be imported ok though... (there are a few warnings and infos but nothing worth mentioning)
Tom
FUDForum. Page generated in 0.04720 seconds
