Home » Archived » Hudson » GIT - clean checkout fails
GIT - clean checkout fails [message #1058291] Mon, 13 May 2013 09:28 Go to next message
Hudson: 3.0.1-b2
Hudson GIT plugin: 2.2.1-h-1
GIT: 1.8.2
Im building GIT project on slave. When a job workspace dir is empty (either I clean it manually via workspace wipe out button or use Git plugin configuration option "Wipe out workspace before build")the build crashes on checkout. After that, on the filesystem I have only one folder .git. It contains standard git folders (but empty) and two files HEAD and config. HEAD contains
ref: refs/heads/master
However, if I run the build again on that folder, the files will be checked out successfully. The problem occures only when the workspace is empty. HEAD content after successfull checkout
b9f5b15f0760d26543ba208d536a2f0c75b94237
Log after 1st attempt (empty workspace - build failed)
Started by user <MyUser>
Building remotely on punt
Checkout:test_git / /hudson/workspace/test_git - hudson.remoting.Channel@3e8eae1e:punt
Using strategy: Default
Last Built Revision: Revision b9f5b15f0760d26543ba208d536a2f0c75b94237 (origin/master)
Checkout:test_git / /hudson/workspace/test_git - hudson.remoting.LocalChannel@1a254ec
Cloning the remote Git repository
Cloning repository origin
ERROR: Error cloning remote repo 'origin' : Could not clone <MyGitRepo>
ERROR: Cause: Exception caught during execution of fetch command
Trying next repository
ERROR: Could not clone repository
FATAL: Could not clone
hudson.plugins.git.GitException: Could not clone
	at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:957)
	at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:889)
	at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2052)
	at hudson.remoting.UserRequest.perform(UserRequest.java:107)
	at hudson.remoting.UserRequest.perform(UserRequest.java:41)
	at hudson.remoting.Request$2.run(Request.java:276)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:439)
	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:895)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:918)
	at java.lang.Thread.run(Thread.java:680)
Log after 2nd attempt (workspace remains after 1st attempt - build successful)
Fetching changes from the remote Git repository
Fetching upstream changes from <MyGitRepo>
Commencing build of Revision b9f5b15f0760d26543ba208d536a2f0c75b94237 (origin/master)
Checking out Revision b9f5b15f0760d26543ba208d536a2f0c75b94237 (origin/master)
[DEBUG] Skipping watched dependency update; build not configured with trigger: test_git #138
Finished: SUCCESS
The problem is always reproducible.
[Updated on: Mon, 13 May 2013 09:30] by Moderator
Re: GIT - clean checkout fails [message #1058328 is a reply to message #1058291] Mon, 13 May 2013 10:53 Go to previous messageGo to next message
Hi I saw this couple of times. I will investigate this. Are you cloning from Github. This happens when I clone from Github using HTTPS protocol.
Re: GIT - clean checkout fails [message #1058443 is a reply to message #1058328] Tue, 14 May 2013 02:55 Go to previous messageGo to next message
Yes, I'm using HTTPS protocol as well but I'm not cloning from Github but from our internal corporate Git server.
Re: GIT - clean checkout fails [message #1058516 is a reply to message #1058443] Tue, 14 May 2013 07:46 Go to previous messageGo to next message
We had this issue a lot. We use Git with SSH. I've seen this with Github projects as well as internal Gerrit projects. As a result we do not clean the workspace but use "Clean after checkout" until this is fixed.
Re: GIT - clean checkout fails [message #1058698 is a reply to message #1058516] Tue, 14 May 2013 13:55 Go to previous messageGo to next message
Hi K.Z & Reinhard, please read the comments in this issue https://bugs.eclipse.org/bugs/show_bug.cgi?id=407887. Henrik, mention he sees the same issue, but could be fixed with some permission settings. However, the plugin should give proper error message.
[Updated on: Tue, 14 May 2013 13:56] by Moderator
Re: GIT - clean checkout fails [message #1058788 is a reply to message #1058698] Wed, 15 May 2013 02:30 Go to previous messageGo to next message
Thanks or referring to the bug. I made a comment there because I don't think it is a permissions issue in our case.
Re: GIT - clean checkout fails [message #1058817 is a reply to message #1058788] Wed, 15 May 2013 04:54 Go to previous messageGo to next message
Henrik provided solution to the configuration issue he created first and it does not apply to the scenario where you checkout from a different machine.
[Updated on: Wed, 15 May 2013 04:55] by Moderator
Re: GIT - clean checkout fails [message #1058898 is a reply to message #1058817] Wed, 15 May 2013 11:27 Go to previous messageGo to next message
Ok, appears the issue is different from that mentioned in the bug. I'll try to fix it ASAP.
Re: GIT - clean checkout fails [message #1058970 is a reply to message #1058898] Thu, 16 May 2013 01:21 Go to previous messageGo to next message
Unfortunately I'm not able to reproduce it. I made sure the workspace was clean. The build was successful
Started by user anonymous
Building remotely on Fedora-slave
Checkout:Test / /home/wjprakash/hudson-slave/workspace/Test - hudson.remoting.Channel@5507d9e4:Fedora-slave
Last Built Revision: Revision ec69988ea1db2f064e818e8c81cd9afb8eb48bde (origin/master)
Checkout:Test / /home/wjprakash/hudson-slave/workspace/Test - hudson.remoting.LocalChannel@6de1bddb
Fetching upstream changes from git://github.com/hudson3-plugins/htmlpublisher-plugin.git
Commencing build of Revision ec69988ea1db2f064e818e8c81cd9afb8eb48bde (origin/master)
Checking out Revision ec69988ea1db2f064e818e8c81cd9afb8eb48bde (origin/master)
Finished: SUCCESS
Re: GIT - clean checkout fails [message #1058971 is a reply to message #1058970] Thu, 16 May 2013 01:25 Go to previous messageGo to next message
Could you try with this git plugin. The only difference is, I have added full stack print when the exception happens, for me to identify the error.
https://dl.dropboxusercontent.com/u/13144273/git.hpi
Also the git on the slave
[wjprakash@riverview ~]$ git --version
git version 1.7.11.7
And the global git config set as
[wjprakash@riverview ~]$ cat .gitconfig
[user]
	email = winston.prakash@gmail.com
	name = Winston Prakash
Re: GIT - clean checkout fails [message #1059036 is a reply to message #1058971] Thu, 16 May 2013 07:15 Go to previous messageGo to next message
Great! Thank to the full stack trace we can identify the problem, btw why it is not always enabled? It looks like there is a problem with authorization on the first attemp. I keep repo credentials in .netrc file. So what is the problem?
Clean checkout
Started by user zapalak
Checkout:test-git / /hudson2/workspace/test-git - hudson.remoting.Channel@37dd0b4c:punt
Last Built Revision: Revision 27964cc90aad85d37cc6379c89cc4eb6467ceb1e (origin/master)
Checkout:test-git / /hudson2/workspace/test-git - hudson.remoting.LocalChannel@32b6481e
ERROR: Error cloning remote repo 'origin' : Could not clone https://<MyGitRepo>/SeeingAssistant/SeeingAssistant-Routes
hudson.plugins.git.GitException: Could not clone https://<MyGitRepo>/SeeingAssistant/SeeingAssistant-Routes
	at hudson.plugins.git.GitAPI.clone(GitAPI.java:234)
	at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:942)
Caused by: org.eclipse.jgit.api.errors.JGitInternalException: Exception caught during execution of fetch command
	at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:145)
	at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:174)
	at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:118)
	at hudson.plugins.git.GitAPI$1.invoke(GitAPI.java:224)
	at hudson.plugins.git.GitAPI$1.invoke(GitAPI.java:218)
	at hudson.FilePath.act(FilePath.java:791)
	at hudson.FilePath.act(FilePath.java:773)
	at hudson.plugins.git.GitAPI.clone(GitAPI.java:218)
	... 12 more
Caused by: org.eclipse.jgit.errors.TransportException: https://<MyGitRepo>/SeeingAssistant/SeeingAssistant-Routes: not authorized
	at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:446)
	at org.eclipse.jgit.transport.TransportHttp.openFetch(TransportHttp.java:276)
	at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:127)
	at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:113)
	at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1062)
	at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:136)
	... 19 more
	at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:958)
2nd attempt
Fetching upstream changes from https://<MyGitRepo>/SeeingAssistant/SeeingAssistant-Routes
Commencing build of Revision 27964cc90aad85d37cc6379c89cc4eb6467ceb1e (origin/master)
Checking out Revision 27964cc90aad85d37cc6379c89cc4eb6467ceb1e (origin/master)
Notifying upstream projects of job completion
[DEBUG] Skipping watched dependency update; build not configured with trigger: test-git #8
Finished: SUCCESS
git version
punt:~ builder$ git --version
git version 1.8.2
global config
punt:~ builder$ cat .gitconfig
[user]
      email=ttbuildserver@gmail.com
      name=builder
[Updated on: Thu, 16 May 2013 07:16] by Moderator
Re: GIT - clean checkout fails [message #1059041 is a reply to message #1059036] Thu, 16 May 2013 08:02 Go to previous messageGo to next message
I tried it and responded directly on the bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=407887#c6
Re: GIT - clean checkout fails [message #1059115 is a reply to message #1059041] Thu, 16 May 2013 16:01 Go to previous messageGo to next message
KZ, Reinhard, I've added new comment to the issue
https://bugs.eclipse.org/bugs/show_bug.cgi?id=407887#c7
Re: GIT - clean checkout fails [message #1065500 is a reply to message #1059115] Wed, 26 June 2013 03:39 Go to previous messageGo to next message
The problem is obviously connected with authorization process. First checkout is successful when I clone from public repository. I tried both .netrc and credential.helper (osxkeychain in my case - MACOS) to store credentials and they works fine from command line but not from Hudson.
1) .netrc
1st checkout (clone?) fails (Caused by: hudson.plugins.git.GitException: org.eclipse.jgit.api.errors.TransportException: https://<URL>/test/test: not authorized)
2nd and next checkouts (fetch?) are successful
2) osxkeychain
2nd and next checkouts (fetch) are failure(Command "git fetch -t https://<URL>/test/test +refs/heads/*:refs/remotes/origin/*" returned status code 128: fatal: could not read Username for 'https://<URL>': Device not configured
Similar issue is described here https://github.com/kemayo/sublime-text-2-git/issues/176
How do you cache your GIT credentials for HTTPS connections ? It seems as if Hudson Git plugin (v2.2.3) cannot take advantege of it now.
Regards!
Re: GIT - clean checkout fails [message #1170077 is a reply to message #1065500] Mon, 04 November 2013 06:45 Go to previous messageGo to next message
Hi, I've added new comment to the issue
icon10.gif  Re: GIT - clean checkout fails [message #1171685 is a reply to message #1170077] Tue, 05 November 2013 07:09 Go to previous messageGo to next message
Hi, I've managed to resolve my clean SSH clone issue - I've added resolution as comment to the issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=407887#c14
Re: GIT - clean checkout fails [message #1480775 is a reply to message #1171685] Thu, 20 November 2014 08:21 Go to previous messageGo to next message
Hi I am also facing the same problem
First time git clone is failing and second time its working fine.
Hudson version I am using is 3.2.1 and git version is 1.8.5.2
Git plugin version is 2.2.8.
Do we have any permanent fix for this ? Or do I need to do the modification in the known_hosts file?
Thanks in advance for the help!!
Error I am getting is :
hudson.plugins.git.GitException: Could not clone git@server:test.git
at hudson.plugins.git.GitAPI.clone(GitAPI.java:255)
at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:1063)
at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:1008)
at hudson.FilePath.act(FilePath.java:793)
at hudson.FilePath.act(FilePath.java:775)
at hudson.plugins.git.GitSCM.gerRevisionToBuild(GitSCM.java:1008)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:777)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1550)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:607)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:518)
at hudson.model.Run.run(Run.java:1493)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:44)
at hudson.model.ResourceController.execute(ResourceController.java:82)
at hudson.model.Executor.run(Executor.java:137)
Caused by: hudson.plugins.git.GitException: org.eclipse.jgit.api.errors.TransportException: git@server:test.git: UnknownHostKey: server. RSA key fingerprint is 62:ad:32:1a:da:52:4c:41:a4:d8:c0:a8:0b:80:c3:d3
at hudson.plugins.git.GitAPI$1.invoke(GitAPI.java:248)
at hudson.plugins.git.GitAPI$1.invoke(GitAPI.java:235)
at hudson.plugins.git.GitAPI.clone(GitAPI.java:235)
... 13 more
Caused by: org.eclipse.jgit.api.errors.TransportException: git@server:test.git: UnknownHostKey: server. RSA key fingerprint is 62:ad:32:1a:da:52:4c:41:a4:d8:c0:a8:0b:80:c3:d3
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:139)
at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:178)
at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:125)
at hudson.plugins.git.GitAPI$1.invoke(GitAPI.java:242)
... 17 more
Caused by: org.eclipse.jgit.errors.TransportException: git@server:test.git: UnknownHostKey: server. RSA key fingerprint is 62:ad:32:1a:da:52:4c:41:a4:d8:c0:a8:0b:80:c3:d3
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:142)
at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:121)
at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:248)
at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:147)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:136)
at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:122)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1111)
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:130)
... 20 more
Caused by: com.jcraft.jsch.JSchException: UnknownHostKey: server. RSA key fingerprint is 62:ad:32:1a:da:52:4c:41:a4:d8:c0:a8:0b:80:c3:d3
at com.jcraft.jsch.Session.checkHost(Session.java:786)
at com.jcraft.jsch.Session.connect(Session.java:342)
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:116)
... 27 more
FATAL: Could not clone repository
hudson.plugins.git.GitException: Could not clone repository
at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:1074)
[Updated on: Thu, 20 November 2014 08:44] by Moderator
Re: GIT - clean checkout fails [message #1481161 is a reply to message #1480775] Thu, 20 November 2014 15:23 Go to previous messageGo to next message
Some how this problem occurs with git version less than 1.9.x. Is it possible to upgrade to git version 1.9.x or higher.
Re: GIT - clean checkout fails [message #1486754 is a reply to message #1481161] Tue, 25 November 2014 04:06 Go to previous messageGo to next message
Thanks Prakash.
I am getting Nothing to do failures as well.. Is that too because git version ?
I am using latest git plugin 2.2.1
Error :-
Started by user nsukumaran
Checkout:workspace / /data03/app/hudson/Hudson_home/teams/SCM/jobs/SCM.GIT_Fetch_Test/workspace - hudson.remoting.LocalChannel@4c53ab
Fetching upstream changes from git@server:test.git
Nothing to do
[DEBUG] Skipping watched dependency update for build: SCM.GIT_Fetch_Test #2 due to result: FAILURE
Finished: FAILURE
Re: GIT - clean checkout fails [message #1488133 is a reply to message #1486754] Wed, 26 November 2014 05:41 Go to previous messageGo to next message
even after we upgraded to 1.9.4, the issue still persists.
Re: GIT - clean checkout fails [message #1495775 is a reply to message #1488133] Tue, 02 December 2014 09:02 Go to previous messageGo to next message
Please help me to figure out these two issues with git in Hudson..
1) Git clone is getting failed for the first time and whenever the workspace is clean.
2)I am getting Nothing to do failure .
Nothing to do
Finished: FAILURE
Please help me to resolve this issue ,
Re: GIT - clean checkout fails [message #1503530 is a reply to message #1495775] Mon, 08 December 2014 09:55 Go to previous messageGo to next message
"Nothing to do" failure is resolved for me
I had to provide the branch specifier as origin/branch name.
Still have the clone issue while workspace is empty.
The error is : Caused by: com.jcraft.jsch.JSchException: USERAUTH fail
If anybody knows about this authentication failure. please let me know to resolve it.
Re: GIT - clean checkout fails [message #1506593 is a reply to message #1488133] Wed, 10 December 2014 19:26 Go to previous message
Really!!, Hmm.. we tested on few slave machines, this issue (Git clone failure after WS clean) does not happen with git version 1.9.x and later.
[Updated on: Wed, 10 December 2014 19:27] by Moderator
Previous Topic:Hudson with HTTPS
Next Topic:hudson job failing
Current Time: Tue Sep 16 06:04:00 EDT 2025
Powered by FUDForum. Page generated in 0.09027 seconds
