Home » Archived » Jubula » Left shortcuts after uninstalling the plugin
Left shortcuts after uninstalling the plugin [message #1053918] Wed, 08 May 2013 03:17 Go to next message
i have installed the jubula plugin for eclipse 4.2 x64 yesterday (via market place) and removed it again today (also via marketplace). unfortunately there are some jubula shortcuts left which interfere with the std. shortcuts and are not changeable/deleteable.
For example "F3" (usually "open declaration") now opens a small yellow popup where i am asked which action i want to trigger ("open declaration" or "open s&pecification").
Is there any trick how to get rid of those shortcuts?
thx, br klemensl
Re: Left shortcuts after uninstalling the plugin [message #1058493 is a reply to message #1053918] Tue, 14 May 2013 07:12 Go to previous messageGo to next message
Thanks for the information! I wasn't aware of this up until now - could you open a ticket in the Jubula Bugzilla?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Jubula
I'm also not aware of anything you can do to get rid of them (but then I'm not the best person to ask) - if you ask again on the ticket, then someone may be able to make a suggestion.
Thanks!
Alex
Re: Left shortcuts after uninstalling the plugin [message #1058785 is a reply to message #1058493] Wed, 15 May 2013 02:02 Go to previous messageGo to next message
Thank you for the answer - I'll open a ticket!
Re: Left shortcuts after uninstalling the plugin [message #1058807 is a reply to message #1058785] Wed, 15 May 2013 03:59 Go to previous messageGo to next message
For all those who run into the same problem: I have deleted all "jubula" related shortcuts in the file [your-workspace]\.metadata\.plugins\org.eclipse.e4.workbench\workbench.xmi => works again!
Re: Left shortcuts after uninstalling the plugin [message #1058819 is a reply to message #1058807] Wed, 15 May 2013 05:02 Go to previous message
Hi Klemens,
Thanks for putting in the ticket [1] and for posting your workaround. I'm going to add the workaround to the ticket as well.
Alex
https://bugs.eclipse.org/bugs/show_bug.cgi?id=408079
Previous Topic:Problem with testexec and autrun not reproductible in ITE
Next Topic:Problem with executing external command on remote machine with 'Local' parameter set on false
Current Time: Thu Jul 24 23:10:49 EDT 2025
Powered by FUDForum. Page generated in 0.49867 seconds
