Home » Eclipse Projects » Remote Application Platform (RAP) » RAP-2.0 - UnsupportedOperationException in SimpleLifeCycle.sleep() Using JDialog.open().(java.lang.UnsupportedOperationException in SimpleLifeCycle.sleep() Using JDialog.open().)
RAP-2.0 - UnsupportedOperationException in SimpleLifeCycle.sleep() Using JDialog.open(). [message #1058486] Tue, 14 May 2013 07:02 Go to next message
In converting an existing RAP 1.4 to 2, I ran into an issue JFace Dialog.open(). When I call open() on a JFace Dialog Extended class I get a continuous stream of exceptions from the runloop. (see snippet below).
The exception is thrown in the SimpleLifeCycle.sleep() method.
  public void sleep() {
    String msg = "Display#sleep() not supported in current operation mode.";
    throw new UnsupportedOperationException( msg );
Obviously this lifecycle doesn't like to sleep. Do I need a different LifeCycle? If so, how/where do I get/set that?
I have checked the 1.5 and the 2.0 Migration instructions but didn't see anything in there (unless I missed it).
I have seen people suggest using swt.Dialog instead. Not sure that is the right approach.
Other than this issue the migration seems to be fairly painless, so: "good job to the RAP team".
java.lang.UnsupportedOperationException: Display#sleep() not supported in current operation mode.
at org.eclipse.rap.rwt.internal.lifecycle.SimpleLifeCycle.sleep(SimpleLifeCycle.java:75)
at org.eclipse.swt.widgets.Display.sleep(Display.java:1200)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:843)
at org.eclipse.jface.window.Window.open(Window.java:818)
Any Help is Highly appreciated.
Kind Regards,
Erwin
Re: RAP-2.0 - UnsupportedOperationException in SimpleLifeCycle.sleep() Using JDialog.open(). [message #1058541 is a reply to message #1058486] Tue, 14 May 2013 08:27 Go to previous messageGo to next message
Hi Erwin,
blocking dialogs are only supported in SWT compatibility mode [1],
supporting this API requires a dedicated UI thread on the server.
However, you can use JFace dialogs in the default mode if you set them
to non-blocking (call dialog.setBlockOnOpen(false)) and override the
methods okPressed, cancelPressed, etc. to react on the results.
HTH, Ralf
[1]
http://eclipse.org/rap/developers-guide/devguide.php?topic=application-setup.html&version=2.0
Ralf Sternberg
Twitter: @EclipseRAP
Re: RAP-2.0 - UnsupportedOperationException in SimpleLifeCycle.sleep() Using JDialog.open(). [message #1058766 is a reply to message #1058541] Tue, 14 May 2013 20:40 Go to previous message
Awesome Ralf, thanks for your help.
Erwin
Previous Topic:How to let the user move something over the screen?
Next Topic:RAP and BIRT
Current Time: Sun Jul 27 08:14:44 EDT 2025
Powered by FUDForum. Page generated in 0.03422 seconds
