Home » Modeling » TMF (Xtext) » Common applicable quick fix(Performing quick fixes on multiple markers)
Common applicable quick fix [message #1034453] Fri, 05 April 2013 08:55 Go to next message
Hi!
One of our users tried to select multiple (similar) entries in the Problems View, and chose 'Quick Fix' from the context menu. They got the famous message:
"The selected problems do not have a common applicable quick fix."
The markers come from our DslJavaValidator class and they have quick fixes defined in our DslQuickfixProvider class. I read a bit, and it sounds like multiple quick fixes can only be applied if they extend WorkbenchMarkerResolution.
I opened the type hierarchy for IMarkerResolution in Eclipse and found Xtext implements IMarkerResolution2 instead of extending WorkbenchMarkerResolution (I'm sure for good reason). But I wonder, can anyone offer a recommendation for supporting the application of multiple, similar quick fixes from the Problems View?
Re: Common applicable quick fix [message #1058255 is a reply to message #1034453] Mon, 13 May 2013 07:38 Go to previous messageGo to next message
Hi Joey,
did you find a way to get multiple quick-fix support?
Hendrik.
Re: Common applicable quick fix [message #1058509 is a reply to message #1058255] Tue, 14 May 2013 07:32 Go to previous message
Hendrik,
Unfortunately I did not - this is still an open issue for our project.
Previous Topic:Generate mydsl Plug-in with Updatesite
Next Topic:Making validator work
Current Time: Sun Jul 27 09:31:21 EDT 2025
Powered by FUDForum. Page generated in 0.04213 seconds
