Home » Modeling » TMF (Xtext) » Generate mydsl Plug-in with Updatesite (using export works, using updatesite is missing an option)
Generate mydsl Plug-in with Updatesite [message #1058105] Sat, 11 May 2013 06:58 Go to next message
I've made a DSL with XText and XTend wich works. Now I want to use it in an standalone Eclipse. First I tryed to export my DSL with "Deployable plug-ins and fragments". First attemd faild, but if I check "use class files compiled in the workspace"like said in the link: http://www.eclipse.org/forums/index.php/m/1051984/ and it works.
Now I want to use an Update-Site with features like it's shown here: www.roperia.com/article/363/building-xtext-plugins-with-maven-and-tycho-a-step-by-step-guide
After I build the site I get the same error as with exporting and not checking the "use class files compiled in the workspace".
So my Question is, how do I tell the Update-Site-Projekt or the used Feature to "use class files compiled in the workspace" ?
Thanks for any Help
Liroth
Re: Generate mydsl Plug-in with Updatesite [message #1058127 is a reply to message #1058105] Sun, 12 May 2013 03:16 Go to previous messageGo to next message
You may want to use the Xtext Buckminster wizard to create the update
site, which works out of the box. I wrote a tutorial about that
http://www.lorenzobettini.it/2012/11/building-xtext-projects-with-buckminster/
hope this helps
Lorenzo
On 05/12/2013 03:14 AM, Liroth Lustim wrote:
> Hello,
> Thanks for any Help
> Liroth
HOME: http://www.lorenzobettini.it
Re: Generate mydsl Plug-in with Updatesite [message #1058492 is a reply to message #1058127] Tue, 14 May 2013 07:11 Go to previous message
Thank you for your help, this worked.
And thank you very much for your tutorial, it's very good.
Liroth
Previous Topic:How to restrict a rule
Next Topic:Common applicable quick fix
Current Time: Sun Jul 27 01:16:56 EDT 2025
Powered by FUDForum. Page generated in 0.04092 seconds
