Debug perspective with "scriptlib" folder [message #1058201] |
Mon, 13 May 2013 04:11  |
When we deploy jars in the Eclipse viewer plugin "scriptlib" folder, we can use relevant java classes (in this example, "org.test.MyDummyClass") in the report, and it runs correctly. But when we switch to the debug perspective it won't work, we always get this error:
Quote:>>>> Debugger exception occured:
>>>> Exit script.
org.mozilla.javascript.EcmaError: TypeError: [JavaPackage org.test.MyDummyClass] is not a function, it is object. (/report/method[@name="initialize"]#1)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3654)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRuntime.java:3632)
at org.mozilla.javascript.ScriptRuntime.typeError(ScriptRuntime.java:3660)
at org.mozilla.javascript.ScriptRuntime.typeError2(ScriptRuntime.java:3679)
at org.mozilla.javascript.ScriptRuntime.notFunctionError(ScriptRuntime.java:3734)
at org.mozilla.javascript.ScriptRuntime.notFunctionError(ScriptRuntime.java:3722)
at org.mozilla.javascript.Interpreter.interpretLoop(Interpreter.java:3363)
at script(/report/method[@name="initialize"]:1)
at org.mozilla.javascript.Interpreter.interpret(Interpreter.java:2487)
at org.mozilla.javascript.InterpretedFunction.call(InterpretedFunction.java:164)
at org.mozilla.javascript.SecurityController$1.exec(SecurityController.java:193)
at org.eclipse.birt.report.engine.javascript.ScriptUtil$1.execWithDomain(ScriptUtil.java:59)
at org.mozilla.javascript.SecurityController.callWithDomain(SecurityController.java:189)
at org.mozilla.javascript.Interpreter.interpret(Interpreter.java:2474)
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFactory.java:398)
at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime.java:3065)
at org.mozilla.javascript.InterpretedFunction.exec(InterpretedFunction.java:175)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.evaluate(JavascriptEngine.java:290)
at org.eclipse.birt.core.script.ScriptContext.evaluate(ScriptContext.java:154)
at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:781)
at org.eclipse.birt.report.engine.executor.ExecutionContext.evaluate(ExecutionContext.java:710)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.handleScriptInternal(ScriptExecutor.java:117)
at org.eclipse.birt.report.engine.script.internal.ScriptExecutor.handleScript(ScriptExecutor.java:104)
at org.eclipse.birt.report.engine.script.internal.ReportScriptExecutor.handleInitialize(ReportScriptExecutor.java:84)
at org.eclipse.birt.report.engine.api.impl.EngineTask.loadDesign(EngineTask.java:1847)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:217)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:112)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.createReportDocument(ReportLauncher.java:632)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.renderReport(ReportLauncher.java:555)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.run(ReportLauncher.java:461)
at org.eclipse.birt.report.debug.internal.core.launcher.ReportLauncher.main(ReportLauncher.java:105)
at org.eclipse.birt.report.debug.internal.core.ReportDebugger.start(ReportDebugger.java:39)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
The only workaround seems to add theses jars as report resources instead, but in our case we want to avoid this. Did anyone succeed to use the debug perspective with a report using java classes deployed in ths "scriptlib" folder?
Thanks!
FUDForum. Page generated in 0.03237 seconds
