Derby DB with ClientDriver [message #1058299] |
Mon, 13 May 2013 09:44  |
I am a beginner with Eclipse scout ( and new within this forum ). i have started to learn with the minicrm example. This example is fine and it's run also after the deployment on Tomcat as a Server Web application. Now my problem is the derby DB.
i would like to integrate the DB not as Embebed (...jdbc.EmbeddedDriver).
i have connected with the example SimpleApp.jave (from derby.zip ) the derby BD
driver = "org.apache.derby.jdbc.ClientDriver";
protocol = "jdbc:derby://localhost:1527/";
connection and results are as expected.
now, i have changed simple the file "DerbySqlService.jave" with
>jdbc:derby://localhost:1527/c:/DerbyDB";
deployed on Tomcat- webapps as before, start Tomcat, download the zip, start Derby Server and try the example.
the result is
Fehler
Die ursprüngliche Fehlermeldung ist:
Verarbeitungsfehler
ProcessingException[ProcessingStatus[ERROR code=0 Calling IStandardOutlineService.getCompanyTableData() / Verarbeitungsfehler]]
at org.eclipse.scout.rt.client.servicetunnel.AbstractServiceTunnel.invokeService(AbstractServiceTunnel.java:167)
at org.eclipse.scout.rt.client.servicetunnel.http.internal.InternalHttpServiceTunnel.invokeService(InternalHttpServiceTunnel.java:175)
at org.eclipse.scout.rt.client.servicetunnel.http.HttpServiceTunnel.invokeService(HttpServiceTunnel.java:115)
at org.eclipse.scout.rt.client.servicetunnel.ServiceTunnelInvocationHandler.invoke(ServiceTunnelInvocationHandler.java:47)
at $Proxy16.getCompanyTableData(Unknown Source)
at eclipse.prg.minicrm.client.ui.desktop.outlines.pages.CompanyTablePage.execLoadTableData(CompanyTablePage.java:38)
at org.eclipse.scout.rt.client.ui.desktop.outline.pages.AbstractPageWithTable.execPopulateTable(AbstractPageWithTable.java:242)
at org.eclipse.scout.rt.client.ui.desktop.outline.pages.AbstractPageWithTable.loadTableDataImpl(AbstractPageWithTable.java:652)
at org.eclipse.scout.rt.client.ui.desktop.outline.pages.AbstractPageWithTable.loadChildren(AbstractPageWithTable.java:715)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTreeNode.ensureChildrenLoaded(AbstractTreeNode.java:909)
at org.eclipse.scout.rt.client.ui.desktop.outline.DefaultPageChangeStrategy.pageChanged(DefaultPageChangeStrategy.java:43)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline.handleActivePageChanged(AbstractOutline.java:429)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline.access$0(AbstractOutline.java:422)
at org.eclipse.scout.rt.client.ui.desktop.outline.AbstractOutline$P_OutlineListener.treeChanged(AbstractOutline.java:465)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.fireTreeEventInternal(AbstractTree.java:2177)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.fireNodesSelected(AbstractTree.java:2014)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.selectNodes(AbstractTree.java:1659)
at org.eclipse.scout.rt.client.ui.basic.tree.AbstractTree.selectNode(AbstractTree.java:1619)
at org.eclipse.scout.rt.client.ui.desktop.AbstractDesktop.setOutline(AbstractDesktop.java:896)
at eclipse.prg.minicrm.client.ui.desktop.Desktop.execOpened(Desktop.java:71)
at org.eclipse.scout.rt.client.ui.desktop.AbstractDesktop$P_LocalDesktopExtension.desktopOpenedDelegate(AbstractDesktop.java:1730)
at org.eclipse.scout.rt.client.ui.desktop.AbstractDesktop$P_UIFacade.fireDesktopOpenedFromUI(AbstractDesktop.java:1814)
at org.eclipse.scout.rt.ui.swt.AbstractSwtEnvironment$2.run(AbstractSwtEnvironment.java:461)
at org.eclipse.scout.rt.ui.swt.concurrency.SwtScoutSynchronizer$1.runVoid(SwtScoutSynchronizer.java:60)
at org.eclipse.scout.rt.client.ClientJob.runStatus(ClientJob.java:189)
at org.eclipse.scout.rt.client.ClientJob.runTransactionWrapper(ClientJob.java:172)
at org.eclipse.scout.rt.client.ClientJob.run(ClientJob.java:159)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
how can i use thet derby-DB as a DB server?
rudolf
FUDForum. Page generated in 0.04518 seconds
