Home » Archived » BIRT » Report Designer Will Not Generate PDF
Report Designer Will Not Generate PDF [message #1058254] Mon, 13 May 2013 07:19 Go to next message
I have been running the same instance of BIRT Report Designer (Juno Release 2 - Build id: 20130225-0426). Last week I began having a problem running (viewing) reports as PDF or running with BIRT Viewer and then printing as PDF.
The report starts, displays the Parameter Dialog and then launches a white window with a small black square in the top left corner.
A screen shot of the window is attached.
HELP!
Jim
  • Attachment: BirtPDF.pdf
    (Size: 23.60KB, Downloaded 491 times)
Re: Report Designer Will Not Generate PDF [message #1058428 is a reply to message #1058254] Tue, 14 May 2013 01:31 Go to previous message
What does your report consist of? Are you using the internal browser? If so, you might try switching to use an external browser. To do this, go to Window -> Preferences -> Report Design -> Preview and check the use external browsers checkbox.
Previous Topic:displaying Image base64
Next Topic:Sort button on x-axis is disabled
Current Time: Sat Jul 26 06:14:43 EDT 2025
Powered by FUDForum. Page generated in 0.05078 seconds
