Kepler M7 war product [message #1058195] |
Mon, 13 May 2013 03:51  |
I have installed M7 and am trying to deploy the application to Tomcat. It deploys OK with 2.0.0 target. I created a new war file under M7 and try to deploy it but get the following errors in the work/catalina/localhost/swb/eclipse/configuration folder.
I don't have any version constraint on javax.servlet in my application.
The war generates fine (the extension bundle problem has gone).
The war product tooling is 0.3.0.201305070844
Rap Tools 2.1.0.20130506-1346
I have an import for javax.servlet, its forbidden so you can't "require" it.
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: SWB
Bundle-SymbolicName: swb3.rwt
Bundle-Version: 1.0.0.qualifier
Bundle-Activator: swb3.rwt.Activator
Bundle-RequiredExecutionEnvironment: JavaSE-1.7
Bundle-ActivationPolicy: lazy
Require-Bundle: org.eclipse.rap.rwt;bundle-version="" could not be resolved. Reason: Missing Constraint: Import-Package: javax.servlet; version="2.3.0"
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.equinox.http.servlet 4 0 2013-05-13 08:28:42.677
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.http.servlet_1.1.400.v20130418-1354 " could not be resolved. Reason: Missing Constraint: Import-Package: javax.servlet; version="[2.3.0,3.1.0)"
!ENTRY org.eclipse.equinox.http.servletbridge 4 0 2013-05-13 08:28:42.683
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.http.servletbridge_1.0.300.v20130327-1442 " could not be resolved. Reason: Missing Constraint: Import-Package: javax.servlet; version="2.3.0"
!ENTRY org.eclipse.equinox.servletbridge 4 0 2013-05-13 08:28:42.686
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.servletbridge_1.2.300.v20130419-1721 " could not be resolved. Reason: Missing Constraint: Import-Package: javax.servlet; version="2.3.0"
!ENTRY org.eclipse.rap.jface 4 0 2013-05-13 08:28:42.690
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.rap.jface_2.1.0.20130506-1748 " could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.rwt; bundle-version="[2.1.0,3.0.0)"
!ENTRY org.eclipse.rap.rwt 4 0 2013-05-13 08:28:42.694
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.rap.rwt_2.1.0.20130506-1610 " could not be resolved. Reason: Missing Constraint: Import-Package: javax.servlet; version="[2.3.0,4.0.0)"
!ENTRY org.eclipse.rap.rwt.osgi 4 0 2013-05-13 08:28:42.698
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.rap.rwt.osgi_2.1.0.20130506-1748 " could not be resolved. Reason: Missing Constraint: Import-Package: javax.servlet; version="[2.5.0,4.0.0)"
!ENTRY swb3.rwt 4 0 2013-05-13 08:28:42.703
!STACK 0
org.osgi.framework.BundleException: The bundle "swb3.rwt_1.0.0.201305130828 [22]" could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.rap.rwt; bundle-version="[2.0.0,3.0.0)"
!ENTRY org.eclipse.osgi 4 0 2013-05-13 08:28:42.706
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.http.registry_1.1.300.v20130402-1529.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2013-05-13 08:28:42.707
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.http.servlet_1.1.400.v20130418-1354.jar was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.http.servletbridge_1.0.300.v20130327-1442.jar was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.servletbridge_1.2.300.v20130419-1721.jar was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.rap.jface_2.1.0.20130506-1748.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2013-05-13 08:28:42.708
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.rap.rwt_2.1.0.20130506-1610.jar was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.rap.rwt.osgi_2.1.0.20130506-1748.jar was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/swb3.rwt_1.0.0.201305130828.jar was not resolved.
FUDForum. Page generated in 0.30822 seconds
