Generation of theTransformation in a java application [message #1058078] |
Fri, 10 May 2013 16:05  |
I would like to run the transformation of models in a Java application.I found this link:
http://www.eclipse.org/forums/index.php/m/632793/?srch=launch+transformation+from+java+file#msg_632793
which demonstrates the same example in ATL tutorial:Families2Persons.I don't know how to run it:is it in an ATL project or in a Java project?Is it enough to copy the code in the previous link and it runs successfully?And if it is in a java project how to solve the problem of the import of libraries related to org.eclipse.m2m.atl.
Please I really need to run the example in the link because if it runs with the example of Families2Persons it will run with any couple of metamodels(afder doing some modifications of course).
I will be grateful if you answer me as soon as possible.
FUDForum. Page generated in 0.06405 seconds
