Home » Modeling » TMF (Xtext) » Missing type info in JvmType model
Missing type info in JvmType model [message #1057941] Thu, 09 May 2013 19:09 Go to next message
I'm using Xbase and the JvmType model for a DSL that among others
supports referring to Swing events by a simple name, e.g. action for a
JTextField. To find out which events are allowed for a specific class, I
search among all the features for operations with names like
addXxxListener and removeXxxListener. If there exists a pair like that
Xxx is an valid action name. E.g. JTextField has addActionListener and
removeActionListener. As an extra check I test that the qualified name
of the type of the first parameter of both are the same, in this case
ActionListener. I also use this type later, to generate code for an
implementation of the listener.
The strange thing is that suddenly the JvmType model seems to be missing
some types. E.g. JTextField.removeActionListener has type info for its
first parameter, while JTextField.addActionListener hasn't (it's null).
Hence, my code crashes when testing their qualified name. What can be
causing this kind of behavior (it worked at some point, but now
consistently doesn't)? What code is actually loading this information
and from where?
Hallvard
Re: Missing type info in JvmType model [message #1058064 is a reply to message #1057941] Fri, 10 May 2013 13:41 Go to previous message
My fault, sorry for the disturbance. My code created a new class that
implemented a listener interface. Hence, I had added a (type reference
to) the listener interface to the class' superTypes list. Unfortunately,
this was the same type reference that was in the JvmType model, so it
was effectively removed from its previous container, in this case the
addActionListener method's first formal parameter. Adding a call to
typeRef.cloneWithProxies solved it.
I notice that all calls to builder methods, like toField, take care to
do this, but when adding directly to lists like a class' superTypes,
this will not happen.
Hallvard
> and from where?
> Regards,
> Hallvard
Previous Topic:XText entry rule
Next Topic: emulate return functions and objects in xbase???
Current Time: Wed Jul 23 06:47:52 EDT 2025
Powered by FUDForum. Page generated in 0.24720 seconds
