Problems with Eclipselink batching statements [message #1057898] |
Thu, 09 May 2013 11:43  |
In my code, I'm making consecutive calls to a stored procedure (with different params each time) in a single transaction.
Ex:
@Transactional
void callProcedure(String... params){
for (String s : params){
callProcedure(s);
void callProcedure(String s){
StoredProcedureCall sp = new StoredProcedureCall();
sp.setProcedureName("SomeProcedure");
sp.addNamedArgument("paramName",s);
Query dq = JpaHelper.createQuery(new DataModifyQuery(sp), m_entityManager);
dq.executeUpdate();
So, I would think that the following code:
callProcedure("firstParam","secondParam");
Would make 2 calls to the stored procedure (one for each param) when the transaction is committed.
However, it seems like somewhere down the line, those 2 calls are getting merged into a single call to the procedure, with multiple parameters. Inspecting the statement in org.eclipse.persistence.platform.database.oracle.Oracle10Platform.executeBatch(Statement, boolean) shows a single call with multiple bind params. This causes failures since my procedure is only expecting a single parameter.
A workaround i found is to do a different call after each procedure call in the loop. This forces the stored procedure to be executed multiple times instead of being consolidated into a single call.
Ex:
callProcedure(s);
m_entityManager.find(SomeClass.class, 1);
Is this expected behavior? Is there another way to get past this (other than doing a bogus EntityManager call)?
Using eclipselink 2.3.1.v20111018-r10243 with Spring Transactions (org.springframework.orm.jpa.JpaTransactionManager) and a shared entity manager.
Re: Problems with Eclipselink batching statements [message #1058677 is a reply to message #1058638] |
Tue, 14 May 2013 12:44   |
So I was incorrect in my previous response. When disabling batch completely, the consecutive calls work fine (was a bug in my code). However below is the output when batch mode is turned on. We can certainly use the query hint as a workaround going forward (when we are able to move 2.5), but this behavior doesn't seem right.
Here is the log from the s/p calls:
[EL Finer]: 2013-05-14 12:29:31.118--ClientSession(1251127504)--Connection(1371161697)--Thread(Thread[[ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--Begin batch statements
[EL Fine]: 2013-05-14 12:29:31.118--ClientSession(1251127504)--Connection(1371161697)--Thread(Thread[[ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--BEGIN FD_DDL_UTIL.table_sync(ptable_name=>?); END;
[EL Fine]: 2013-05-14 12:29:31.118--ClientSession(1251127504)--Connection(1371161697)--Thread(Thread[[ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])-- bind => [CO_PROJECT_CP_FC]
[EL Fine]: 2013-05-14 12:29:31.118--ClientSession(1251127504)--Connection(1371161697)--Thread(Thread[[ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])-- bind => [CO_PROJECT_CP_FT]
[EL Finer]: 2013-05-14 12:29:31.118--ClientSession(1251127504)--Connection(1371161697)--Thread(Thread[[ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--End Batch Statements
[EL Fine]: 2013-05-14 12:29:31.12--ClientSession(1251127504)--Thread(Thread[[ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--SELECT 1 FROM DUAL
[EL Warning]: 2013-05-14 12:29:31.128--UnitOfWork(1687571951)--Thread(Thread[[ACTIVE] ExecuteThread: '4' for queue: 'weblogic.kernel.Default (self-tuning)',5,Pooled Threads])--Local Exception Stack:
Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.2.v20111125-r10461): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: java.sql.BatchUpdateException: invalid arguments in call
Error Code: 17433
Caused by: java.sql.BatchUpdateException: invalid arguments in call
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1357)
at oracle.jdbc.driver.OraclePreparedStatement.sendBatch(OraclePreparedStatement.java:3905)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.sendBatch(OraclePreparedStatementWrapper.java:1432)
at weblogic.jdbc.wrapper.PreparedStatement_oracle_jdbc_driver_OraclePreparedStatementWrapper.sendBatch(Unknown Source)
at org.eclipse.persistence.platform.database.oracle.Oracle10Platform.executeBatch(Oracle10Platform.java:44)
at org.eclipse.persistence.internal.databaseaccess.DatabaseAccessor.executeJDK12BatchStatement(DatabaseAccessor.java:860)
... 81 more
FUDForum. Page generated in 0.07200 seconds
