Home » Archived » BIRT » Spanning Columns Across Pages
Spanning Columns Across Pages [message #1057776] Wed, 08 May 2013 12:39 Go to next message
I have a Data Set which contains 20-30 different columns. I would like to have columns 1-10 on page 1, columns 11-20 on page 2, and columns 21-30 on page 3. If there are too many rows for one page, the three pages should repeat (so columns 1-10 would be on pages 1 and 4, columns 11-20 on pages 2 and 5, columns 21-30 on pages 3 and 6).
Is this possible in BIRT? If so, how?
Thanks!
Re: Spanning Columns Across Pages [message #1057893 is a reply to message #1057776] Thu, 09 May 2013 11:16 Go to previous message
If you select your table so that the row and column tabs show, then select the 10th column, go to the page break section of the property editor, and set the page break after to always. Then, do the same for the 20th column, you should get this result. Let me know.
Previous Topic:Creating a Stacked Bar chart using a script
Next Topic:Where is the BIRT 4.2 API?
Current Time: Wed Nov 05 12:02:31 EST 2025
Powered by FUDForum. Page generated in 0.03668 seconds
