Home » Archived » Test and Performance Tools Platform (TPTP) » UnknownHostException when profiling URL.openStream()
UnknownHostException when profiling URL.openStream() [message #105450] Wed, 18 July 2007 03:45 Go to next message
I just ran into an UnknownHostException when profiling a little piece of
code that does nothing more than
try {
URL url = new URL("http://www.eclipse.org");
url.openStream();
} catch (MalformedURLException e) {
e.printStackTrace();
} catch (IOException e) {
Running the code without profiling would work. However profiling it throws
the exception saying www.eclipse.org is an unknown host.
Eclipse Europa + TPTP Java 1.5 WinXP
Any Ideas ?
Philipp
Re: UnknownHostException when profiling URL.openStream() [message #105687 is a reply to message #105450] Thu, 19 July 2007 02:56 Go to previous messageGo to next message
Philipp Tiedt wrote:
> try {
> url.openStream();
> throws the exception saying www.eclipse.org is an unknown host.
> Any Ideas ?
> Philipp
Philipp,
This seems like an environment configuration problem. If you are behind
a Firewall or a Proxy server, it is likely that the Java environment
used by Eclipse is configured to pass the Proxy/Firewall while the
environment used by the Profiler (actually, the Agent Controller) is not
properly configured.
Here's an example, if you are behind a proxy server, adding the
following command line options to the VM argument will resolve the
problem (replace the mock up values with real ones):
-Dhttp.proxyHost=proxy.mycompany.com -Dhttp.proxyPort=8080
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: UnknownHostException when profiling URL.openStream() [message #105729 is a reply to message #105687] Thu, 19 July 2007 06:51 Go to previous message
Thx Asaf,
works !!
Previous Topic:Profiling Jboss 4.0.3SP1 with TPTP 4.4 from europe build
Next Topic:Newbie: AGR hangs
Current Time: Thu Jul 24 23:14:47 EDT 2025
Powered by FUDForum. Page generated in 0.28560 seconds
