Home » Modeling » Epsilon » Automatically add child-nodes upon creation
Automatically add child-nodes upon creation [message #1053465] Mon, 06 May 2013 03:01 Go to next message
Hi all,
I was wondering if it is possible to when I create a node in the diagram I by default create a child-node as well?
The way it looks now I create an Object and I have to add a child-node ObjectData to it before saving (because of XText grammar require the child-node). But I was wondering if I can maybe type in the ECore2GMF file, the emf file or something similar that when I create a Object node it will also generate a ObjectData node inside it?
(The reason I have constructed it like this is so that I can minimize all the data and only show the Objects label for a better overview when I have many objects)
Thanks for any help
Write you later / Mårten
Re: Automatically add child-nodes upon creation [message #1053577 is a reply to message #1053465] Mon, 06 May 2013 11:07 Go to previous messageGo to next message
Hi Marten,
Eugenia can only do what the GMF models can do, and I think they don't allow for this kind of customization.
You might want to customize the *CreateCommand for your model element type in the "edit.commands" subpackage of your ".diagram" plugin. I think the "doExecuteWithResult" method might be the right one.
No problem,
Antonio
Re: Automatically add child-nodes upon creation [message #1053647 is a reply to message #1053577] Tue, 07 May 2013 02:49 Go to previous messageGo to next message
Hello Antonio
Ok, I thought it might be like that but it never hurts to ask Smile
Will take a look at the files you recommended, although it might not be until next week because of school work popping up like crazy Smile, but thanks for letting me know where to look.
Re: Automatically add child-nodes upon creation [message #1053770 is a reply to message #1053647] Tue, 07 May 2013 10:28 Go to previous messageGo to next message
No problem Smile. If you get it to work, it'd be great if you could post how you did it here, for future reference.
Re: Automatically add child-nodes upon creation [message #1056056 is a reply to message #1053770] Wed, 08 May 2013 07:17 Go to previous message
I found a solution to the problem, and it only needed two lines of code Smile
In the class <YourParentObject>CreateCommand you go to the function doExecuteWithResult.
	protected CommandResult doExecuteWithResult(IProgressMonitor monitor,
			IAdaptable info) throws ExecutionException {
		idainfront.iipax.dsl.iiDsl.ObjectDefinition newElement = idainfront.iipax.dsl.iiDsl.IiDslFactory.eINSTANCE
				.createObjectDefinition();
		idainfront.iipax.dsl.iiDsl.Objectbase owner = (idainfront.iipax.dsl.iiDsl.Objectbase) getElementToEdit();
		owner.getObjectTypes().add(newElement);
		// These are the two lines you need to add in the function
		// IiDsl is my name for MyDsl
		// Object is my child node and ObjectDefinition is my parent node so newObject will be placed in the newElement
		idainfront.iipax.dsl.iiDsl.Object newObject = IiDslFactory.eINSTANCE.createObject();
		newElement.setObject(newObject);
		doConfigure(newElement, monitor, info);
		((CreateElementRequest) getRequest()).setNewElement(newElement);
		return CommandResult.newOKCommandResult(newElement);
I got the solution from this thread.
Previous Topic:Illegal Name of EWL
Next Topic:Epsilon Validation Language
Current Time: Sat Jul 26 11:49:24 EDT 2025
Powered by FUDForum. Page generated in 0.11842 seconds
