Home » Eclipse Projects » JFace » TextViewerUndoManager(check if there is anything on the undo stack)
TextViewerUndoManager [message #1052618] Tue, 30 April 2013 06:00 Go to next message
Hi there,
is there a way to check if there is sth on the undo or redo stack?
I'm using the SourceViewer with a TextViewerUndoManager. I tried redoable() and undoable() but they are not what I'm looking for.
I tried to extend the TextViewerUndoManager, but I dont know how to get access to the undo/redo stack.
So... is there either another class that I can use? Maybe another UndoManager or would you suggest another TextEditor? (I just need copy/paste, undo/redo, and maybe some highlighting). Or do you know another way how to check if there is sth on the undo stack?
Thank you!
Re: TextViewerUndoManager [message #1054154 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Is there noone who uses an textEditor with undo/redo possibilities?
Re: TextViewerUndoManager [message #1054197 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054233 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054270 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054308 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054347 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054386 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054426 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054467 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054507 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054549 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054590 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054633 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054675 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054718 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054764 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054809 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054862 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054915 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1054968 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055023 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055084 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055143 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055204 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055269 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055335 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055400 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055469 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055538 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055608 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055682 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055755 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055833 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055909 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1055988 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056069 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056151 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056235 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056322 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056411 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056503 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056596 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056691 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056788 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056888 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1056988 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1057090 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1057195 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1057299 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1057404 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1057514 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Re: TextViewerUndoManager [message #1057622 is a reply to message #1052618] Wed, 08 May 2013 04:21 Go to previous message
Previous Topic:TableColumnLayout problem on mac os
Next Topic:Position-preserving undo/redo
Current Time: Wed Jul 23 12:22:21 EDT 2025
Powered by FUDForum. Page generated in 0.48034 seconds
