Home » Modeling » EMF » [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exists
[Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exists [message #1053742] Tue, 07 May 2013 09:07 Go to next message
We're creating a RCP application and we use EMF resources to load our data. We're in need of calling an Oracle stored procedure to modify our data. After the procedure we want to refresh one single object, but that causes some problems.
This is our simplified model:
- Folder
-- documents : Document (opposite: folder)
- Document
-- folder : Folder (opposite: documents)
Our procedure deletes a document from the database so we want to refresh our folder. I expected the documents reference to update automatically, but instead it tries to load the deleted object. This is the error we get:
org.hibernate.UnresolvableObjectException: No row with the given identifier exists: [Document#1161401]
	at org.hibernate.UnresolvableObjectException.throwIfNull(UnresolvableObjectException.java:64)
	at org.hibernate.event.internal.DefaultRefreshEventListener.onRefresh(DefaultRefreshEventListener.java:159)
	at org.hibernate.internal.SessionImpl.fireRefresh(SessionImpl.java:1044)
	at org.hibernate.internal.SessionImpl.refresh(SessionImpl.java:1029)
	at org.hibernate.engine.spi.CascadingAction$3.cascade(CascadingAction.java:205)
	at org.hibernate.engine.internal.Cascade.cascadeToOne(Cascade.java:380)
	at org.hibernate.engine.internal.Cascade.cascadeAssociation(Cascade.java:323)
	at org.hibernate.engine.internal.Cascade.cascadeProperty(Cascade.java:208)
	at org.hibernate.engine.internal.Cascade.cascadeCollectionElements(Cascade.java:409)
	at org.hibernate.engine.internal.Cascade.cascadeCollection(Cascade.java:350)
	at org.hibernate.engine.internal.Cascade.cascadeAssociation(Cascade.java:326)
	at org.hibernate.engine.internal.Cascade.cascade(Cascade.java:165)
	at org.hibernate.event.internal.DefaultRefreshEventListener.onRefresh(DefaultRefreshEventListener.java:123)
	at org.hibernate.event.internal.DefaultRefreshEventListener.onRefresh(DefaultRefreshEventListener.java:64)
	at org.hibernate.internal.SessionImpl.fireRefresh(SessionImpl.java:1036)
	at org.hibernate.internal.SessionImpl.refresh(SessionImpl.java:1013)
	at org.hibernate.internal.SessionImpl.refresh(SessionImpl.java:1008)
This is the code we execute after the procedure:
session.refresh(folder);
On this forum I read the not-found="ignore" prevents the error from happening but I can't set this because I use the EOpposite...
Does anyone know how to solve this?
Thanks in advance!
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1053755 is a reply to message #1053742] Tue, 07 May 2013 09:56 Go to previous messageGo to next message
I finally found how to achieve the not-found="ignore" functionality, doing:
@NotFound(action=NotFoundAction.IGNORE)
But this solves part of the problem.. now it complains for every reference inside the document.. So it ignores the document, but it tries to refresh the references of it. That doesn't make sense.. Should the ignore be set on every reference?
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1053776 is a reply to message #1053755] Tue, 07 May 2013 10:36 Go to previous messageGo to next message
Replying on my own post again..
When setting PersistenceOptions.CASCADE_POLICY_ON_NON_CONTAINMENT to 'PERSIST' instead of 'MERGE, PERSIST, REFRESH' it works.
Now I only have to find out what effect this has on my application..
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1053849 is a reply to message #1053776] Tue, 07 May 2013 17:14 Go to previous messageGo to next message
Hi Ricky,
This cascade setting means that the merge and refresh actions are not cascaded to the referenced objects. Depending on
what the stored procedure changes this may or may not be a good idea...
Btw, you can also iterate/walk over the object graph yourselve to do refresh explicitly if you want it to be cascaded.
gr. Martin
> works.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1053940 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Ok, but when I do want the refresh/merge I need to set the @NotFound in every reference below my Document? Because the refresh will produce an error when something is deleted?
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1053941 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Ok, but when I do need the refresh/merge I have to set the @NotFound in every reference below my Document? Otherwise it produces an error when refreshing after a Document is deleted
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1053956 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1053957 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1053978 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1053979 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054002 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054003 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054026 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054027 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054055 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054056 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054084 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054085 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054114 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054115 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054145 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054146 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054179 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054180 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054216 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054217 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054254 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054255 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054291 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054292 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054330 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054331 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054370 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054371 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054410 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054411 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054450 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054451 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054491 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054492 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054532 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054533 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054574 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054575 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054616 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054617 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054659 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054660 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054701 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054702 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054744 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054745 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054791 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054792 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054839 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054840 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054891 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054892 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054944 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054945 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1054999 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055000 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055055 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055056 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055117 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055118 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055178 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055179 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055241 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055242 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055306 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055307 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055373 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055374 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055439 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055440 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055509 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055510 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055579 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055580 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055651 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055652 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055725 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055726 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055798 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055799 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055876 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055877 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055954 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1055955 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056033 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056034 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056114 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056115 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056199 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056200 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056285 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056286 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056373 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056374 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056462 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056463 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056554 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056555 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056649 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056650 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056745 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056746 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056843 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056844 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056944 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1056945 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057045 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057046 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057150 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057151 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057254 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057255 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057359 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057360 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057465 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057466 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057577 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057578 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057686 is a reply to message #1053849] Wed, 08 May 2013 03:38 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057687 is a reply to message #1053849] Wed, 08 May 2013 03:39 Go to previous messageGo to next message
Re: [Teneo] session refresh throws UnresolvableObjectException: No row with the given identifier exi [message #1057769 is a reply to message #1057687] Wed, 08 May 2013 11:57 Go to previous message
Hi Ricky,
The best approach is to remove refresh from the cascade option (so set the CASCADE_POLICY_ON_NON_CONTAINMENT to only
PERSIST and MERGE).
Then refresh the objects you want to refresh explicitly, so if you refresh a parent then if also the children need to be
refreshed to do that explicitly for each one of them.
Or could it be that the object itself is already deleted? In that case I would catch the exception and remove the object
from the resource explicitly also.
gr. Martin
The Netherlands
Previous Topic:Mixed feature delegation across type hierarchy/genmodels
Next Topic:[EMF] Choose internally used EList (sets which use '==' or 'equals')
Current Time: Wed Jul 23 22:58:46 EDT 2025
Powered by FUDForum. Page generated in 0.27140 seconds
