Home » Eclipse Projects » JFace » SWTException: Widget is disposed in TableViewer with ObservableListContentProvider
SWTException: Widget is disposed in TableViewer with ObservableListContentProvider [message #1053219] Fri, 03 May 2013 04:12 Go to next message
I have placed two buttons for moving TableItems UP and DOWN besides a TableViewer, which has an ObservableListContentProvider and therefore has an IObservableList as input.
Here is the code for moving the items in the IObservableList
    // The move action can be 1 or -1
    public void moveSelected(List<IViewerItem> currentInput, int moveAction) {
        // get selection
        Collection<IViewerItem> selectedRows = getSelectedRows();
        if (selectedRows == null) {
            return;
        // get range (indices) of selected items
        int count = currentInput.size();
        if (count == 0) {
            return;
        int minRowIndex = count - 1;
        int maxRowIndex = 0;
        for (IViewerItem item : selectedRows) {
            int index = currentInput.indexOf(item);
            if (index < minRowIndex) {
                minRowIndex = index;
            if (index > maxRowIndex) {
                maxRowIndex = index;
        // is move up allowed
        if ((ListFormItem.ONE_POSITION_UP == moveAction) && (minRowIndex < 1)) {
            return;
        // is move down allowed?
        if ((ListFormItem.ONE_POSITION_DOWN == moveAction)
                && (maxRowIndex >= (count - 1))) {
            return;
        // move items
        if (currentInput instanceof IObservableList) {
            Iterator<IViewerItem> iterator = selectedRows.iterator();
            while (iterator.hasNext()) {
                IViewerItem iViewerItem = (IViewerItem) iterator.next();
                int currentIndex = currentInput.lastIndexOf(iViewerItem);
                ((IObservableList) currentInput).move(currentIndex,
                        currentIndex + moveAction);
                viewer.setSelection(new StructuredSelection(iViewerItem));
Most of the time this works quite well, but sometimes, when moving the items the following Exception occurs:
org.eclipse.swt.SWTException: Widget is disposed
    at org.eclipse.swt.SWT.error(SWT.java:4083)
    at org.eclipse.swt.SWT.error(SWT.java:3998)
    at org.eclipse.swt.SWT.error(SWT.java:3969)
    at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
    at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:340)
    at org.eclipse.swt.widgets.Widget.getData(Widget.java:525)
    at org.eclipse.jface.viewers.StructuredViewer.disassociate(StructuredViewer.java:639)
    at org.eclipse.jface.viewers.AbstractTableViewer.internalRemove(AbstractTableViewer.java:794)
    at org.eclipse.jface.viewers.AbstractTableViewer.access$0(AbstractTableViewer.java:767)
    at org.eclipse.jface.viewers.AbstractTableViewer$3.run(AbstractTableViewer.java:834)
    at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1422)
    at org.eclipse.jface.viewers.StructuredViewer.preservingSelection(StructuredViewer.java:1383)
    at org.eclipse.jface.viewers.AbstractTableViewer.remove(AbstractTableViewer.java:832)
    at org.eclipse.jface.viewers.TableViewer.remove(TableViewer.java:413)
    at org.eclipse.jface.viewers.AbstractTableViewer.remove(AbstractTableViewer.java:856)
    at org.eclipse.jface.internal.databinding.viewers.TableViewerUpdater.remove(TableViewerUpdater.java:36)
    at org.eclipse.jface.databinding.viewers.ObservableListContentProvider$2.handleRemove(ObservableListContentProvider.java:124)
    at org.eclipse.core.databinding.observable.list.ListDiff.accept(ListDiff.java:139)
    at org.eclipse.jface.databinding.viewers.ObservableListContentProvider$Impl.handleListChange(ObservableListContentProvider.java:118)
    at org.eclipse.core.databinding.observable.list.ListChangeEvent.dispatch(ListChangeEvent.java:61)
    at org.eclipse.core.databinding.observable.ChangeManager.fireEvent(ChangeManager.java:119)
    at org.eclipse.core.databinding.observable.list.DecoratingObservableList.fireListChange(DecoratingObservableList.java:59)
    at org.eclipse.core.databinding.observable.list.DecoratingObservableList.handleListChange(DecoratingObservableList.java:97)
    at org.eclipse.core.databinding.observable.list.DecoratingObservableList$1.handleListChange(DecoratingObservableList.java:71)
    at org.eclipse.core.databinding.observable.list.ObservableList.fireListChange(ObservableList.java:73)
    at org.eclipse.core.internal.databinding.observable.masterdetail.DetailObservableList.access$1(DetailObservableList.java:1)
    at org.eclipse.core.internal.databinding.observable.masterdetail.DetailObservableList$1.handleListChange(DetailObservableList.java:48)
    at org.eclipse.core.databinding.observable.ChangeSupport.fireEvent(ChangeSupport.java:39)
    at org.eclipse.core.databinding.observable.list.AbstractObservableList.fireListChange(AbstractObservableList.java:114)
    at org.eclipse.core.internal.databinding.property.list.SimplePropertyObservableList.notifyIfChanged(SimplePropertyObservableList.java:567)
    at org.eclipse.core.internal.databinding.property.list.SimplePropertyObservableList.updateList(SimplePropertyObservableList.java:182)
    at org.eclipse.core.internal.databinding.property.list.SimplePropertyObservableList.set(SimplePropertyObservableList.java:428)
    at org.eclipse.core.databinding.observable.list.DecoratingObservableList.set(DecoratingObservableList.java:192)
    at org.eclipse.core.internal.databinding.observable.masterdetail.DetailObservableList.set(DetailObservableList.java:169)
    at mypackage.SelectedViewerItemsListener.move(SelectedViewerItemsListener.java:173)
    at mypackage.SelectedViewerItemsListener.moveSelected(SelectedViewerItemsListener.java:150)
    at mypackage.MoveListItemListener.modifyListInput(MoveListItemListener.java:45)
    at mypackage.AbstractModifyListInputListener.widgetSelected(AbstractModifyListInputListener.java:40)
    at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
    at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
    at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
    at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
    at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
    at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
    at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
    at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
    at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
    at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
    at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
    at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
    at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
    at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Does anyone have an idea how to solve this problem or can offer a workaround?
Simon
Re: SWTException: Widget is disposed in TableViewer with ObservableListContentProvider [message #1053878 is a reply to message #1053219] Wed, 08 May 2013 01:26 Go to previous messageGo to next message
Hello Simon,
In whcih line are you getting this exception?
Re: SWTException: Widget is disposed in TableViewer with ObservableListContentProvider [message #1057987 is a reply to message #1053219] Fri, 10 May 2013 06:50 Go to previous message
Hello Snehil,
thanks for your reply.
The Exception is caused by this line.
The internal list of the TableViewer is updated and by the databinding mechanisms the Table is also updated, because of the update on the list order.
But sporadically the Widget Disposes error occurs.
Simon
Previous Topic:Open all children of a treeviewer node
Next Topic:ListViewer: List items in horizontal order
Current Time: Mon Jul 28 18:07:43 EDT 2025
Powered by FUDForum. Page generated in 0.04566 seconds
