[CDO] We are trying to get CDO running on Oracle 11g [message #1053689] |
Tue, 07 May 2013 04:50  |
But struggling with this error!
jvm 1 | WrapperListener_start_runner [org.eclipse.net4j.spi.db.DBAdapter] CREATE TABLE cdo_lobs (id VARCHAR2(64), size NUMBER, bdata BLOB, cdata CLOB)
jvm 1 | WrapperListener_start_runner [org.eclipse.net4j.spi.db.DBAdapter] -- ORA-00904: : ugyldig identifikator
jvm 1 |
jvm 1 | WrapperListener_start_runner [org.eclipse.net4j.spi.db.DBAdapter] SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: Error in WrapperListener.start callback. org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: org.eclipse.net4j.db.DBException: Problem with table cdo_lobs: SELECT id, size, bdata, cdata FROM cdo_lobs
jvm 1 | WrapperManager Error: at org.eclipse.net4j.spi.db.DBAdapter.validateTable(DBAdapter.java:447)
I'm using the code from emf-cdo-S20130319-1538 build
Is there some way to make Oracle less sensitive ?
Or is there still some problemes with the OracleAdpater ?
Børre Nordbakken
Brønnøysundregistrene
Re: [CDO] We are trying to get CDO running on Oracle 11g [message #1053808 is a reply to message #1053689] |
Tue, 07 May 2013 12:31   |
The 'size' column should have been renamed to 'lsize' which is not in your case.
AFAIK, that bug was fixed 6 months ago. Are you sure you are using the version you have mentioned?
Børre ordbakken wrote on Tue, 07 May 2013 10:50We are trying to get CDO running on Oracle 11g
jvm 1 |
Børre Nordbakken
FUDForum. Page generated in 0.05645 seconds
