Home » Eclipse Projects » EclipseLink » Incrementing generated primary key in @PrePersist(According to JPA, is it valid and portable to manually increase a JPA-generated primary key in @PrePersists?)
Incrementing generated primary key in @PrePersist [message #1053103] Thu, 02 May 2013 09:02 Go to next message
As my JPA-based program and a third-party non-Java software need to share the same ID Generator, I had to do a trick: The third-party Software expects the value of the generator to be "next id", while JPA expects it to be "last id", so I simply did this:
* Set increment of @TableGenerator to 1, so JPA must SELECT again before each use.
* Added @PostPersist listener to simple switch from "last id" semantics to "next id semantics":
@PrePersist private void prePersist() {
    this.pk.id--;
This actually seems to work pretty well, but I like to know whether this is considered harmful in any particular situation, and whether it is actually a portable solution?
Thanks!
-Markus
[Updated on: Fri, 03 May 2013 02:18] by Moderator
Re: Incrementing generated primary key in @PrePersist [message #1053744 is a reply to message #1053103] Tue, 07 May 2013 09:13 Go to previous messageGo to next message
Not a single comment on this? So I can assume the EclipseLink Team does not see any negative impact? Great! Smile
Re: Incrementing generated primary key in @PrePersist [message #1053784 is a reply to message #1053744] Tue, 07 May 2013 10:57 Go to previous messageGo to next message
You could also create your own Sequence object that does "last id" semantics.
Just subclass the existing TableSequence.
Re: Incrementing generated primary key in @PrePersist [message #1053786 is a reply to message #1053784] Tue, 07 May 2013 11:01 Go to previous message
Sounds much more complex than simply adding a callback. Smile
Previous Topic:Unique Constraints and Delete and Insert Order - Constraint Violation
Next Topic:create a function via nativeQuery
Current Time: Wed Jul 23 12:44:40 EDT 2025
Powered by FUDForum. Page generated in 1.08642 seconds
