Home » Eclipse Projects » EclipseLink » Unique Constraints and Delete and Insert Order - Constraint Violation(Constraint violation removing itens for a list, and adding new)
Unique Constraints and Delete and Insert Order - Constraint Violation [message #1053635] Mon, 06 May 2013 22:23 Go to next message
Hi Folks..
I have this scenario:
class A {
   @Id
   Integer id;
   @OneToMany(cascade=ALL)
   Set<B> bList;
@UniqueConstraint(a, c)
class B {
    @Id
    integer id;
    @ManyToOne
    A a;
    @ManyToOne
    C c;
    ... Some other stuff
private class C {
    @Id
    Integer id;
Adding new B objects on the A list, everything works.
But, if I remove an B Object from the A list, and adds another, with a C relation equals to the removed object, an UniqueConstraint exception occours because eclipselink try to first insert or update the actual objects, and after, delete.
I read on the documentation that this is the normal behavior, and for now, i'm configuring the UnitOfWork of this transaction to perform deletes before, using the setShouldPerformDeleteFirst property. It works.
But theres no other way that I can configure the UniqueConstraint, that Eclipselink will understand that it needs to perform's delete first? Like configuring some kind of ID relation between the two entities (A and C) over the B mapping?
Re: Unique Constraints and Delete and Insert Order - Constraint Violation [message #1053782 is a reply to message #1053635] Tue, 07 May 2013 10:55 Go to previous message
Your best option is to delete the object, then call flush(), then reinsert it. But in general re-incarnating an object is odd, better to have unique Ids, such as using a generated id.
Previous Topic:Is UNION supported in a subquery?
Next Topic:Incrementing generated primary key in @PrePersist
Current Time: Sat Jul 19 02:36:40 EDT 2025
Powered by FUDForum. Page generated in 0.26214 seconds
