Home » Newcomers » Newcomers » Eclipse crash recovery(Recover dependency data from previous workspace)
Eclipse crash recovery [message #1053633] Mon, 06 May 2013 21:11 Go to next message
I am using Eclipse helios in Ubuntu OS. It crashed and did not start up again. The .metadata/.log file had the following error: "An error occurred while automatically activating bundle org.eclipse.core.resources (65)" followed by a lot of exceptions.
The common solution suggested for the above error was to delete .snap file in .metadata/.plugins/org.eclipse.core.resources/.snap. That worked for restarting eclipse, but the project data was lost. Since I did not setup the project dependencies, I am clueless to set it up again. Is there any way to do that from the existing metadata. Thanks in advance for any help!!
Re: Eclipse crash recovery [message #1053760 is a reply to message #1053633] Tue, 07 May 2013 09:56 Go to previous messageGo to next message
If your projects are all still in some workspace somewhere you can
always import existing projects from the file system (the folder where
you have the workspace) into a new workspace.
Re: Eclipse crash recovery [message #1053804 is a reply to message #1053760] Tue, 07 May 2013 12:06 Go to previous message
Thanks Ed. I suppose that is the only way.
Previous Topic:Create an app based on Eclipse (from scratch).
Next Topic:Old Java Program won't open, Why?
Current Time: Sat Jul 26 23:17:38 EDT 2025
Powered by FUDForum. Page generated in 0.08991 seconds
