Home » Eclipse Projects » Eclipse Scout » Missing property changes in Custom Field(handleScoutPropertyChange is not called)
Missing property changes in Custom Field [message #1053581] Mon, 06 May 2013 11:26 Go to next message
I've created two custom fields (drawing some pretty complex stuff using the draw2d library). I've modelled these fields on the DrawLine custom field from the tutorial. Most things seem to work (mainly the drawing part and reporting changes in the drawing back to the client/model).
However, there is one thing I just can't get to work and that is to notify the renderer when the model has changed.
My AbstractBlablaField extends AbstractCustomField and implements IBlablaField which in turn extends IFormField.
I have setXxxx() methods that also set the corresponding property:
  @FormData
  public void setAnordnungsTage(Gueltigkeitstage anordnungsTage) {
    m_anordnungsTage = anordnungsTage;
    propertySupport.setProperty(PROP_ANORDNUNGSTAGE, anordnungsTage);
On the renderer side, I have a SwtScoutBlablaField extending SwtScoutFieldComposite<IBlablaField>. This class also contains the following method:
  protected void handleScoutPropertyChange(String name, Object newValue) {
    if ((name.equals(ITagesfilterField.PROP_FP)) || (name.equals(ITagesfilterField.PROP_ANORDNUNGSTAGE)) || (name.equals(ITagesfilterField.PROP_OPTIONSTAGE))
        || (name.equals(ITagesfilterField.PROP_UNSELEKTIERBAR))) {
      System.out.println("Updating Tagesfilter because of property: " + name);
      updateKalenderFromScout();
    } else {
      System.out.println("No need to update Tagesfilter because of property: " + name);
    super.handleScoutPropertyChange(name, newValue);
However, if I call setAnordnungsTage() in the client, handleScoutPropertyChange() in the renderer is never called.
I am sure I'm missing something very small but extremely obvious, but for the life of me just can't find it...
I'd appreciate any hints you could give me on where to look!
Re: Missing property changes in Custom Field [message #1053619 is a reply to message #1053581] Mon, 06 May 2013 17:21 Go to previous messageGo to next message
Hi Urs
Could it be that the method attachScout is overridden without calling super? Thats the point where the listener is attached.
Claudio
Re: Missing property changes in Custom Field [message #1053681 is a reply to message #1053619] Tue, 07 May 2013 04:40 Go to previous messageGo to next message
Claudio, thanks for that pointer, but that wasn't the issue.
I've tracked down the problem:
In my AbstractBlablaField I used a bean class of which I kept three instances. Based on user input in the drawn interface, I modified these beans from the UIFacade, so the code looked like this:
P_UIFacade.selectionChanged(Date date, boolean selection) {
    Gueltigkeitstage at = getAnordnungsTage();
    at.modify(date, selection);
    setAnordnungsTage();
@FormData
Stepping into propertySupport.setProperty() I found the following:
BasicPropertySupport.setProperty() gets the oldValue using m_props.get(name) and then passes both oldValue and newValue to CompareUtility.equals() which returns true, because both oldValue and newValue reference the same object. Changing my setter to create a new copy solved this problem.
@FormData
    m_anordnungsTage = new Gueltigkeitstage(anordnungsTage);
Re: Missing property changes in Custom Field [message #1053691 is a reply to message #1053681] Tue, 07 May 2013 04:55 Go to previous messageGo to next message
Just some feedback:
Are you sure that creating a new copy is a good Java practice? I do not know your code, but often for cases like this you just need to write the appropriate hashCode() and equals(). Eclipse has a wizard to generate them for you (you need to check or uncheck the relevant java field of your java-bean)
Re: Missing property changes in Custom Field [message #1053709 is a reply to message #1053691] Tue, 07 May 2013 06:54 Go to previous messageGo to next message
I tried that first, but unfortunately it doesn't work because of the following code:
  public boolean BasicPropertySupport.setProperty(String name, Object newValue, Object defaultOldValueWhenNull) {
    Object oldValue = m_props.get(name);  // this will return the reference to the object stored with the last call, which is the same as the reference to the new object
    if (oldValue == null) {
      oldValue = defaultOldValueWhenNull;
    m_props.put(name, newValue);
    if (CompareUtility.equals(oldValue, newValue)) {  // returns true if oldValue == newValue
      // no change
      return false;
    else {
      firePropertyChangeImpl(name, oldValue, newValue);
      return true;
If I don't create a new copy in my setter, oldValue and newValue in setProperty will always be a reference to the same object.
Re: Missing property changes in Custom Field [message #1053775 is a reply to message #1053709] Tue, 07 May 2013 10:35 Go to previous messageGo to next message
You are probably right. If your "Gueltigkeitstage" is mutable and you change some of the field values, the reference is kept but the value represented by the bean is different. Without seeing the case I can not tell.
CompareUtility.equals(oldValue, newValue) => goes on oldValue.equals(newValue) not on "oldValue == newValue" (this utility function also handle some wired cases).
Re: Missing property changes in Custom Field [message #1053881 is a reply to message #1053775] Wed, 08 May 2013 02:07 Go to previous message
Jeremie Bresson wrote on Tue, 07 May 2013 16:35
Yes, that is exactly the situation I had. No worries, creating the copy in the setter works.
You're right. Of course with oldValue==newValue, oldValue.equals(newValue) will always return true.
Previous Topic:SWT: Switching between SearchForm/TableForm-Pairs does not work
Next Topic:Authorization/Permissions: resource-level access
Current Time: Sun Jul 27 13:58:33 EDT 2025
Powered by FUDForum. Page generated in 0.24944 seconds
