Missing property changes in Custom Field [message #1053581] |
Mon, 06 May 2013 11:26  |
I've created two custom fields (drawing some pretty complex stuff using the draw2d library). I've modelled these fields on the DrawLine custom field from the tutorial. Most things seem to work (mainly the drawing part and reporting changes in the drawing back to the client/model).
However, there is one thing I just can't get to work and that is to notify the renderer when the model has changed.
My AbstractBlablaField extends AbstractCustomField and implements IBlablaField which in turn extends IFormField.
I have setXxxx() methods that also set the corresponding property:
@FormData
public void setAnordnungsTage(Gueltigkeitstage anordnungsTage) {
m_anordnungsTage = anordnungsTage;
propertySupport.setProperty(PROP_ANORDNUNGSTAGE, anordnungsTage);
On the renderer side, I have a SwtScoutBlablaField extending SwtScoutFieldComposite<IBlablaField>. This class also contains the following method:
protected void handleScoutPropertyChange(String name, Object newValue) {
if ((name.equals(ITagesfilterField.PROP_FP)) || (name.equals(ITagesfilterField.PROP_ANORDNUNGSTAGE)) || (name.equals(ITagesfilterField.PROP_OPTIONSTAGE))
|| (name.equals(ITagesfilterField.PROP_UNSELEKTIERBAR))) {
System.out.println("Updating Tagesfilter because of property: " + name);
updateKalenderFromScout();
} else {
System.out.println("No need to update Tagesfilter because of property: " + name);
super.handleScoutPropertyChange(name, newValue);
However, if I call setAnordnungsTage() in the client, handleScoutPropertyChange() in the renderer is never called.
I am sure I'm missing something very small but extremely obvious, but for the life of me just can't find it...
I'd appreciate any hints you could give me on where to look!
Re: Missing property changes in Custom Field [message #1053681 is a reply to message #1053619] |
Tue, 07 May 2013 04:40   |
Claudio, thanks for that pointer, but that wasn't the issue.
I've tracked down the problem:
In my AbstractBlablaField I used a bean class of which I kept three instances. Based on user input in the drawn interface, I modified these beans from the UIFacade, so the code looked like this:
P_UIFacade.selectionChanged(Date date, boolean selection) {
Gueltigkeitstage at = getAnordnungsTage();
at.modify(date, selection);
setAnordnungsTage();
@FormData
Stepping into propertySupport.setProperty() I found the following:
BasicPropertySupport.setProperty() gets the oldValue using m_props.get(name) and then passes both oldValue and newValue to CompareUtility.equals() which returns true, because both oldValue and newValue reference the same object. Changing my setter to create a new copy solved this problem.
@FormData
m_anordnungsTage = new Gueltigkeitstage(anordnungsTage);
Re: Missing property changes in Custom Field [message #1053709 is a reply to message #1053691] |
Tue, 07 May 2013 06:54   |
I tried that first, but unfortunately it doesn't work because of the following code:
public boolean BasicPropertySupport.setProperty(String name, Object newValue, Object defaultOldValueWhenNull) {
Object oldValue = m_props.get(name); // this will return the reference to the object stored with the last call, which is the same as the reference to the new object
if (oldValue == null) {
oldValue = defaultOldValueWhenNull;
m_props.put(name, newValue);
if (CompareUtility.equals(oldValue, newValue)) { // returns true if oldValue == newValue
// no change
return false;
else {
firePropertyChangeImpl(name, oldValue, newValue);
return true;
If I don't create a new copy in my setter, oldValue and newValue in setProperty will always be a reference to the same object.
Re: Missing property changes in Custom Field [message #1053881 is a reply to message #1053775] |
Wed, 08 May 2013 02:07  |
Jeremie Bresson wrote on Tue, 07 May 2013 16:35You are probably right. If your "Gueltigkeitstage" is mutable and you change some of the field values, the reference is kept but the value represented by the bean is different. Without seeing the case I can not tell.
Yes, that is exactly the situation I had. No worries, creating the copy in the setter works.
CompareUtility.equals(oldValue, newValue) => goes on oldValue.equals(newValue) not on "oldValue == newValue" (this utility function also handle some wired cases).
You're right. Of course with oldValue==newValue, oldValue.equals(newValue) will always return true.
FUDForum. Page generated in 0.26641 seconds
