Home » Modeling » EMF » Pasting and ID handling(What is the right way to ensure unique IDs when pasting?)
Pasting and ID handling [message #1053579] |
Mon, 06 May 2013 11:12  |
Howdy,
I am looking for the best (right?) approach to ensure unique IDs upon pasting in EMF. Basically, I have model elements with IDs that have to be unique. When elements are created, they receive a unique id (UUID).
I am concerned about clipboard pasting. If elements are cut and pasted, I don't want the IDs to change. But if elements are copied and pasted (or pasted multiple times), I need to generate new IDs for those elements.
So: What's the best approach to do this? I would have expected the ItemProviders to provide a createPasteCommand() method to override, but such a method does not exist.
The EMF Book mentions the PasteFromClipboardCommand, which sounds exactly like what I need. Unfortunately, I am not sure where I would customize such a command.
And last, it would be great if the solution would also work for drag&drop, which can also be used for moving and copying, depending on the keyboard modifier.
Thanks in advance,
- Michael
Re: Pasting and ID handling [message #1053587 is a reply to message #1053579] |
Mon, 06 May 2013 11:42   |
Michael,
Comments below.
On 06/05/2013 5:12 PM, Michael Jastram wrote:
> Howdy,
> (UUID).
> those elements.
No. There is a PasteFromClipboardCommand, but that's a "global" command
created by AdapterFactoryEditingDomain.createCommand.
You could specialize that in your editing domain.
That's the problem. There are several ways to end up with the same
behavior.
Perhaps the simplest way would be to specialize the AddCommand so before
you add something, you check that the ID each object being added
(includes any contained objects) are unique, and if not, that you assign
somehow a unique identifier; you should probably make such changes using
more commands to be sure it's undone...
> Thanks in advance,
> - Michael
Re: Pasting and ID handling [message #1053695 is a reply to message #1053587] |
Tue, 07 May 2013 05:24   |
Hi Ed,
Thanks for your answers, they pretty much pointed me in the right direction.
I modified createAddCommand() and createDragAndDropCommand(), and it's working for both scenarios (copy&paste and drag&drop with copy). I can't think of another scenario that I may have missed.
> so before
To check the unique ID, I am checking against owner.eResource().getIntrinsicIDToEObjectMap().keySet(). Is this a smart way of doing this? In the initialization, I call setIntrinsicIDToEObjectMap(new HashMap<String, EObject>()), to make sure that the lookup is fast.
I don't think so... I modify the values before adding the objects to the model. Undo will therefore simply remove the objects again. Even if the objects are pasted again after an undo, the ids will be checked again. Or am I missing something? The most important thing is that by setting new values, I don't modify the existing model, right? But that should not be the case.
Best,
- Michael
Re: Pasting and ID handling [message #1053699 is a reply to message #1053695] |
Tue, 07 May 2013 05:45  |
Michael,
Comments below.
On 07/05/2013 11:24 AM, Michael Jastram wrote:
> Hi Ed,
> direction.
>> so before you add something, you check that the ID each object being
>> added (includes any contained objects) are unique, and if not, that
>> you assign somehow a unique identifier;
Yes, otherwise a full walk of the tree is necessary. Note that you can
use owner.eResource().getEObject(<id-string>) to check that nothing else
already maps to that ID; this will be either fast or slow depending on
whether you've set the intrinsic ID map, but should always work correct,
and has the advantage that you don't need to rely on Resource
implementation details in your AddCommand.
>> you should probably make such changes using more commands to be sure
>> it's undone...
Yes I think you're right. I think even if you do a Cut, and then do a
Paste, that the object in the clipboard is copied so undoing the paste
and undoing the Cut should not result in the object with modified IDs
being placed back in the tree. Best to test that to be sure...
> Best,
> - Michael
Current Time: Sun Jul 27 08:14:52 EDT 2025
Powered by FUDForum. Page generated in 0.04164 seconds
