Home » Modeling » EMF » EContentAdapter does not always see map values changes
EContentAdapter does not always see map values changes [message #1053559] Mon, 06 May 2013 10:20 Go to next message
I have an issue with EContentAdapter. When I have maps with lists as values, it does not detect that new list instances are added as values. And so no notification is triggered when the list changes. Here is an example that demonstrates it:
Note that if the EContentAdapter is registered after the new BasicEList() is added to the map, it gets the notification correctly
Any idea if this is a bug, or there is a way to do it that would work?
---- xcore
package test
class A {
contains TestMap[] items
class ItemValue {}
class TestMap wraps java.util.Map$Entry{
String key
contains ItemValue [0..*] value
---- test
A a = TestFactory.eINSTANCE.createA();
Adapter listener = new EContentAdapter() {
public void notifyChanged(Notification notification) {
System.out.println(notification);
a.eAdapters().add(listener);
a.getItems().put("key" , new BasicEList<ItemValue>()); // this seems to go unnoticed by EContentAdapter
ItemValue value = TestFactory.eINSTANCE.createItemValue();
a.getItems().get("key").add(value ); // EContentAdapter not notified
[Updated on: Mon, 06 May 2013 10:21] by Moderator
Re: EContentAdapter does not always see map values changes [message #1053565 is a reply to message #1053559] Mon, 06 May 2013 10:39 Go to previous messageGo to next message
David,
Comments below.
I think that's not true. When I run your test case there is one
notification, i.e., for the map entry being added to the items list...
> ---- xcore
> package test
> class A {
> class ItemValue {}
> String key
> ---- test
> @Override
You're not calling super, so the content adapter doesn't attach itself
to the newly added map entry...
> a.eAdapters().add(listener); a.getItems().put("key" , new
> EContentAdapter
Re: EContentAdapter does not always see map values changes [message #1053566 is a reply to message #1053565] Mon, 06 May 2013 10:43 Go to previous messageGo to next message
No Message Body
Re: EContentAdapter does not always see map values changes [message #1053567 is a reply to message #1053566] Mon, 06 May 2013 10:44 Go to previous message
Yes I just realised that too...
David
Previous Topic:Backslashes and spaces in EMF URI's
Next Topic:[Teneo] Using ChangeRecorder and persisting ChangeDescription models
Current Time: Sat Jul 26 11:32:02 EDT 2025
Powered by FUDForum. Page generated in 0.07095 seconds
