Home » Modeling » EMF » EMF editor using remote model through RMI
EMF editor using remote model through RMI [message #1053356] Sat, 04 May 2013 07:44 Go to next message
I have following situation:
I generate an EMF model from annotated Java, and then a Generator Model creates the standard Edit and Editor plugins for this model.
The EMF model is then moved to a powerful server, which takes care of the actual workload.
The Edit/Editor plugins remain on the client and communicate though RMI (Java Remote Objects) with the server.
This was easy to implement for a simple model with only two classes and a few methods. But the model is constantly developed and will soon include some hundred classes with several methods each.
Is there any possibility to have the generated Edit/Editor plugins automatically include the RMI communication code?
Gregor
Re: EMF editor using remote model through RMI [message #1053459 is a reply to message #1053356] Mon, 06 May 2013 02:00 Go to previous messageGo to next message
Gregor,
No, there's no direct support for RMI. But primarily that involves
serializing instances and exchanging those serializations and EMF is
quite good at producing exchangeable serializations...
On 06/05/2013 3:36 AM, Gregor Fichtental wrote:
> Hello,
> Thanks
> Gregor
Re: EMF editor using remote model through RMI [message #1053464 is a reply to message #1053356] Mon, 06 May 2013 02:57 Go to previous messageGo to next message
Did you have a look at EMFStore? It uses RMI to persist ecore models (XMI) to a server and can handle all the communications. The project mentions to be able to handle model evolutions as well.
Gregor Fichtental wrote on Sat, 04 May 2013 13:44
Gregor
Re: EMF editor using remote model through RMI [message #1053513 is a reply to message #1053459] Mon, 06 May 2013 07:02 Go to previous messageGo to next message
The serialisation is not a problem, it is done by RMI.
The only problem was that I have to modify the generated editor after each change to the model. I am now working on making the generated editor more generic and take all its itemproviders, menu entries etc. dynamically from the information in the EPackage.
I think a generic editor plugin would be useful for many situations. Why is the editor plugin generated for each input model to statically include all features? Can we expect a significant speedup from the existing implementation?
Gregor
Re: EMF editor using remote model through RMI [message #1053514 is a reply to message #1053464] Mon, 06 May 2013 07:06 Go to previous messageGo to next message
Thank you, I didn't know about EMFStore. I don't see how it helps for this problem, but it will be definitely helpful elsewhere in my project.
Gregor
Re: EMF editor using remote model through RMI [message #1053531 is a reply to message #1053513] Mon, 06 May 2013 08:11 Go to previous message
Gregor,
Comments below.
I thought it generally use java.io.Serializeable....
Mark your changes @generated not, or simple stop generating the editor.
It pretty much is generic already anyway; try deleting the dependency on
your generated *.edit project and you'll see there are only a few lines
that are model specific (and even these aren't necessary)...
Yes, example from the ComposeItemProviderAdapterFactory.
Yes, I've started working on one.
So that folks would feel comfortable that they have complete control and
can change any part of it to suit their own wishes.
No, not really, it's pretty much a copy of a generic editor.
> Thanks
> Gregor
Previous Topic:Existing Java Source Code to EMF model
Next Topic:Backslashes and spaces in EMF URI's
Current Time: Wed Jul 23 04:07:23 EDT 2025
Powered by FUDForum. Page generated in 0.09265 seconds
