Home » Modeling » ATL » EMFTVM/ATL How to assign the result of a rule matching several elements
EMFTVM/ATL How to assign the result of a rule matching several elements [message #1053440] Sun, 05 May 2013 16:49 Go to next message
Dear all,
progressing in the implementation of a model transformation with EMFTVM, I am facing a new issue: I wrote a matched rule that matches 2 elements but I didn't find out how to store the result of this rule in my model.
Here is a snippet of code to illustrate what I have in my code (sorry if it is not correct, I wrote it directly on the forum):
rule R1
  from
    c: AADL!ComponentInstance
  to
    implImg: AADL!ThreadImplementation
        calls <- c.calls -- list of SubprogramCall
rule R2
  from
    call: AADL!SubprogramCall
  to
    callImg: AADL!SubprogramCall
rule R3
  from
    c: AADL!ComponentInstance,
    (c.entryPoint = call)
  to
Basically, what I would like is that the element created by R1 (implImg) contains in it attribute "calls" the list of SubprogramCall created by R2 or R3. I tried using inheritence (R3 inherits R2) but it did not work. Maybe a "special" resolveTemp could solve my problem...
Any suggestion?
Thanks a lot,
Etienne.
[Updated on: Mon, 06 May 2013 16:34] by Moderator
Re: EMFTVM/ATL How to assign the result of a rule matching several elements [message #1053510 is a reply to message #1053440] Mon, 06 May 2013 06:59 Go to previous messageGo to next message
Maybe something like this could work:
rule R1
from
to
calls <- c.calls, -- list of SubprogramCall
calls <- c.calls -> collect(e | thisModule.resolveTemp(e, 'callImg'))
Re: EMFTVM/ATL How to assign the result of a rule matching several elements [message #1053537 is a reply to message #1053510] Mon, 06 May 2013 08:44 Go to previous messageGo to next message
Dear Javier,
I already tried this solution, but to my understanding R3 is matched by tuples (c, call). So it looks like using resolveTemp on a single element of type SubprogramCall does not work: it returns elements created by R2.
So I guess it all depends on the way EMFTVM stores elements in the trace when rules match tuples of elements. I am investigating but if someone has an answer that would be great!
Etienne.
Re: EMFTVM/ATL How to assign the result of a rule matching several elements [message #1053607 is a reply to message #1053537] Mon, 06 May 2013 15:49 Go to previous messageGo to next message
EMFTVM uses a Sequence instead of a Tuple as trace key, which contains the source elements in order.
In your specific case, you don't need to transform the Cartesian product of 'c' and 'call' in R3. Therefore you can use an explicit mapsTo:
rule R3 {
  from
  to
    callImg: AADL!SubprogramCall mapsTo call
Re: EMFTVM/ATL How to assign the result of a rule matching several elements [message #1053611 is a reply to message #1053607] Mon, 06 May 2013 16:33 Go to previous messageGo to next message
Dennis, your solution just works perfectly, this is awesome!
Just for my information, I tried this:
rule R1
  from
  to
      calls <- c.calls->collect(e| thisModule.resolveTemp(Sequence{c,e}, 'callImg'))
and I get an exception: Cannot resolve default trace target 'callImg' for [the_sender:ComponentInstance, the_call:SubprogramCall]
Is there a mistake in my code? Or do I make a conceptual mistake? Or is it a feature not yet supported?
Thanks again,
Etienne.
Re: EMFTVM/ATL How to assign the result of a rule matching several elements [message #1053612 is a reply to message #1053611] Mon, 06 May 2013 16:45 Go to previous messageGo to next message
I also found (after a rapid googling) this thread on the forum about "what does mapsTo mean":
http://www.eclipse.org/forums/index.php/t/8026/
Considering the answers and the date of the thread, maybe a short refreshment could be good Wink
Dennis, do you have more information to provide on this topic?
Thanks again,
Etienne.
Re: EMFTVM/ATL How to assign the result of a rule matching several elements [message #1053657 is a reply to message #1053612] Tue, 07 May 2013 03:52 Go to previous messageGo to next message
Yes: the semantics of "mapsTo" are slightly more elaborate for EMFTVM, and are currently only described in:
Dennis Wagelaar. A Revised Semantics for Rule Inheritance and Module Superimposition in ATL. Proceedings of the 3rd International Workshop on Model Transformation with ATL (MtATL 2011), pp.63 - 74.
Re: EMFTVM/ATL How to assign the result of a rule matching several elements [message #1057956 is a reply to message #1053657] Fri, 10 May 2013 02:06 Go to previous messageGo to next message
Dear Dennis,
in some cases I have to use the Cartesian product of my model elements. Let's imagine we withdraw R2 from my previous example; can I write R1 like this then?
rule R1
  from
  to
I tried but I get an exception: Cannot resolve default trace target 'callImg' for [the_sender:ComponentInstance, the_call:SubprogramCall]. But I know that R3 matches on this sequence of elements...
Etienne.
[Updated on: Fri, 10 May 2013 03:19] by Moderator
Re: EMFTVM/ATL How to assign the result of a rule matching several elements [message #1058025 is a reply to message #1057956] Fri, 10 May 2013 09:45 Go to previous message
You cannot combine "mapsTo" and resolveTemp() on a Sequence of input elements.
Use either one or the other.
Re: EMFTVM/ATL How to assign the result of a rule matching several elements [message #1058029 is a reply to message #1057956] Fri, 10 May 2013 09:45 Go to previous message
Previous Topic:ATL Transformation Order Problem
Next Topic:Running ATL Transformation in java application
Current Time: Wed Jul 23 12:11:46 EDT 2025
Powered by FUDForum. Page generated in 0.14689 seconds
