SWT: Switching between SearchForm/TableForm-Pairs does not work [message #1053341] |
Sat, 04 May 2013 02:38  |
Dear all.
switching between SearchForm/TableForm-Pairs seems not to work in an SWT-Client.
You can reproduce it with the MiniCRM-Example
If you select "Company" in the StandardTreeView the CompanySearchForm is displayed together with its CompanyTablePage. That is correct.
If you select "Person" in the StandardTreeView the PersonSearchForm is not displayed, only its PersonTablePage. It looks like an bug here (refreshing problem?)
Everything works as expected in the Swing-Client.
Can someone reproduce this behaviour? If so, i can open a new bug ticket.
BW,
Volkert
Eclipse Juno SR2 / Scout 3.8.2
Windows 7 SP1
Java 1.7.0_21
[Updated on: Mon, 06 May 2013 00:12] by Moderator
Re: SWT: Switching between SearchForm/TableForm-Pairs does not work [message #1053509 is a reply to message #1053498] |
Mon, 06 May 2013 06:56  |
Volkert B. wrote on Mon, 06 May 2013 11:53and used it "out of the box".
This version is Eclipse 4.2.2 and Scout 3.8.2
I am not sure if there will be an official release of a Scout 3.8.3 version (maybe as part of a LTS program, but nothing for sure).
Scout 3.9.0 is coming by the end of June. It will be shipped with Eclipse 4.3.0
You can get a preview from this version on this page (developer preview download). This week is still 3.9.0 M6, by the end of the week it will be 3.9.0 M7.
According to Urs and its comment in Bug 388701, your bug might be fixed with this version.
I noticed a lot of other wired behavior when you use 4.x Eclipse runtime in combination with a Scout 3.x. For Scout SWT Application I prefer to use an Eclipse 3.x runtime.
FUDForum. Page generated in 0.04139 seconds
