JSDT project setup from GIT sources [message #963952] |
Tue, 30 October 2012 02:23  |
I get the source of JSDT from GIT (Master branch), but the eclipse complains about the errors below. There are a better branch to clone to start contribute? How to setup this project/environment?
Missing bundles:
org.eclipse.wst.jsdt.core.tests.compiler
org.eclipse.wst.jsdt.core.tests.model
org.eclipse.wst.jsdt.ui.tests
Error about extension points:
Referenced element 'enablement' is not defined quickAssistProcessors.exsd /org.eclipse.wst.jsdt.ui/schema line 57
Referenced element 'enablement' is not defined quickFixProcessors.exsd /org.eclipse.wst.jsdt.ui/schema line 63
And a bunch o JavaScript erros like this:
Syntax error on token "var", invalid MemberExpression IE_var.js /org.eclipse.wst.jsdt.support.ie/libraries line 74
FUDForum. Page generated in 0.04515 seconds
