Home » Modeling » TMF (Xtext) » Design considerations supporting Heredoc with Xtext/antlr lexer
Design considerations supporting Heredoc with Xtext/antlr lexer [message #1053391] Sat, 04 May 2013 20:37 Go to next message
In the Puppet language, there is going to be support for Ruby like
Heredoc expressions. In simple form (but also showing some complexity)
it looks like this.
$a = @(END).upcase
This is the text that is in the heredoc,
and it will be turned to uppercase.
END
I have implemented this in the Puppet language itself, so I know what
needs to be done (it is almost all in the lexer). My questions are about
if there are things I need to think about in Xtext when I do a similar
solution using the custom ANTLR based lexer in Geppetto.
Basically, when seeing '@(' there is lookahead in the lexer that:
a) slurps everything to the closing ')' and checks if this is a valid
heredoc tag (there are some options and parameters too that I did not
show above).
b) skip to end of the line, then slurp everything to the END marker.
c) record the position where regular lexer should continue (after the
END), and at what position the skipping start (at the end of the line).
d) return to the position after the closing ')' of the heredoc tag.
On subsequent calls to the lexer when advancing to the recorded position
for the heredoc start, the lexer skips to the recorded end of the heredoc.
My qustions are: Can I have a queue of tokens in the lexer. In the
runtime implementation this makes it possible to first produce a HEREDOC
token, and then a STRING token with the text, or should I try to creat a
more complex token? The problem is that it contains a discontinuous
sequence of bytes.
Secondly, will this work in Xtext? Basically tokens will appear in a non
linear fashion - i.e. tokens from offsets on line 5 will appear before
say offsets on line 3. Does that matter?
I am greatful if anyone have ideas or advise how to proceed with this.
- henrik
Re: Design considerations supporting Heredoc with Xtext/antlr lexer [message #1053392 is a reply to message #1053391] Sat, 04 May 2013 21:09 Go to previous messageGo to next message
I wonder especially how Xtext uses parser/lexer to process partial
input, this since the lexer now needs to have state. (In my current
implementation I also maintain state (the previous significant token is
remembered since some tokens may only appear after a certain other
token) and this seems to work fine. Now I need something a bit more
elaborate.
So, details on this would be much appreciated. (Or pointers to where to
look in the source).
- henrik
On 2013-05-05 2:37, Henrik Lindberg wrote:
> it looks like this.
> $a = @(END).upcase
> END
> show above).
> sequence of bytes.
> Regards
> - henrik
Re: Design considerations supporting Heredoc with Xtext/antlr lexer [message #1053393 is a reply to message #1053391] Sat, 04 May 2013 21:28 Go to previous messageGo to next message
> sequence of bytes.
Answer found here:
http://www.antlr.org/wiki/pages/viewpage.action?pageId=3604497
That is straight forward (I already have half of that in my current
override).
- henrik
Re: Design considerations supporting Heredoc with Xtext/antlr lexer [message #1053523 is a reply to message #1053393] Mon, 06 May 2013 07:18 Go to previous messageGo to next message
Hi Henrik,
the described approach should work fine with Xtext, as long as you
customize the partial parsing accordingly, e.g. expand the partially
parsed region or initialize the lexer in a proper state.
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 05.05.13 03:28, schrieb Henrik Lindberg:
>> sequence of bytes.
> Answer found here:
> override).
> - henrik
Re: Design considerations supporting Heredoc with Xtext/antlr lexer [message #1053598 is a reply to message #1053523] Mon, 06 May 2013 12:33 Go to previous messageGo to next message
On 2013-06-05 13:18, Sebastian Zarnekow wrote:
> Hi Henrik,
> Regards,
> Sebastian
How do I find the places where partial parsing takes place (I don't have
any that I have introduced afaik) ?
- henrik
Re: Design considerations supporting Heredoc with Xtext/antlr lexer [message #1053649 is a reply to message #1053598] Tue, 07 May 2013 03:06 Go to previous messageGo to next message
Hi Henrik,
it's PartialParsingHelper.reparse(IParser, IParseResult, ReplaceRegion)
Sebastian
Am 06.05.13 18:33, schrieb Henrik Lindberg:
>> Hi Henrik,
>> Regards,
>> Sebastian
> - henrik
Re: Design considerations supporting Heredoc with Xtext/antlr lexer [message #1053732 is a reply to message #1053649] Tue, 07 May 2013 08:23 Go to previous messageGo to next message
- henrik
Re: Design considerations supporting Heredoc with Xtext/antlr lexer [message #1733611 is a reply to message #1053391] Mon, 30 May 2016 08:18 Go to previous message
The link to the antlr wiki is dead by now, but can be retrieved using the wayback machine.
https://web.archive.org/web/20121114142618/http://www.antlr.org/wiki/pages/viewpage.action?pageId=3604497
I stumbled upon this thread trying to write an xtext grammar that includes here-docs. Unfortunately I didn't get how exactly the referred solution can be integrated into xtext.
Has anyone implemented such a here-doc rule in xtext?
Previous Topic:My xtext grammar showing when I am using object specifier inside expression
Next Topic:TemplateProposal does not get inserted any more
Current Time: Wed Jul 23 07:35:53 EDT 2025
Powered by FUDForum. Page generated in 0.05682 seconds
