Home » Modeling » TMF (Xtext) » How I can get the contents of my DSL file(In runtime)
How I can get the contents of my DSL file [message #1053368] Sat, 04 May 2013 12:27 Go to next message
I have my grammar for xbase...and my interpreter that evaluate var declaration.. when my user click on context menu option interpreter.. I tell the interpreter and give
String model = "var x = account(xxx)\n var y = account(xxxxxx)\n var z = 0\n z = x + y";
.. but.. how I can give to my interpreter the contents of the Editor which gave click?????..is my interpreter good implementation???... look at jEEjecutableExtension file in org.example.go.ui... thanks you by read this
Re: How I can get the contents of my DSL file [message #1053370 is a reply to message #1053368] Sat, 04 May 2013 12:33 Go to previous messageGo to next message
i am not sure if i get your problem.
http://christiandietrich.wordpress.com/2011/10/15/xtext-calling-the-generator-from-a-context-menu/
Re: How I can get the contents of my DSL file [message #1053371 is a reply to message #1053370] Sat, 04 May 2013 12:36 Go to previous messageGo to next message
You may have a look at https://github.com/cdietrich/mql/blob/master/org.eclipse.xtext.mql.ui/src/org/eclipse/xtext/mqrepl/ui/handler/ModelQueryInterpreterHandler.java
too
Re: How I can get the contents of my DSL file [message #1053373 is a reply to message #1053370] Sat, 04 May 2013 12:44 Go to previous messageGo to next message
yes, I use http://christiandietrich.wordpress.com/2011/10/15/xtext-calling-the-generator-from-a-context-menu/...sorry for mi english..thanks
Re: How I can get the contents of my DSL file [message #1053375 is a reply to message #1053373] Sat, 04 May 2013 12:54 Go to previous messageGo to next message
And what is your problem?
Re: How I can get the contents of my DSL file [message #1053376 is a reply to message #1053375] Sat, 04 May 2013 12:58 Go to previous messageGo to next message
And please make sure you use YoutdslExecutableExtensionFactory in your plugin.xml for the handler class.
Re: How I can get the contents of my DSL file [message #1053377 is a reply to message #1053376] Sat, 04 May 2013 13:16 Go to previous messageGo to next message
Thanks Christian.. is very good https://github.com/cdietrich/mql/blob/master/org.eclipse.xtext.mql.ui/src/org/eclipse/xtext/mqrepl/ui/handler/ModelQueryInterpreterHandler.java but .. how can get
ModelQueryLanguageView
..??? and where YoutdslExecutableExtensionFactory, in plugin.xml the org.example.go or org.example.go.ui???
Re: How I can get the contents of my DSL file [message #1053378 is a reply to message #1053377] Sat, 04 May 2013 13:17 Go to previous messageGo to next message
Hi the ui. As i do it in my blog
Re: How I can get the contents of my DSL file [message #1053379 is a reply to message #1053378] Sat, 04 May 2013 13:26 Go to previous messageGo to next message
I go now for you Blog.. can you tell me the exact url???...I'll put your name in the acknowledgments of my thesis ... I can??
Re: How I can get the contents of my DSL file [message #1053381 is a reply to message #1053379] Sat, 04 May 2013 13:33 Go to previous messageGo to next message
See 5. posts above
Re: How I can get the contents of my DSL file [message #1053382 is a reply to message #1053381] Sat, 04 May 2013 14:05 Go to previous message
Fine.. works...thanks very....my jEEjecutableExtension.java final look ...
public Object execute(ExecutionEvent event) throws ExecutionException {
		// TODO Auto-generated method stub
		// Obteniendo el contenido del archivo
		IEditorPart activeEditor = HandlerUtil.getActiveEditor(event);
        final XtextEditor editor = (XtextEditor) activeEditor;
        XtextDocument doc = (XtextDocument) editor.getDocument();
        String r = doc.get();
        // Inject
        GOActivator.getInstance().getInjector("org.example.go.GO").injectMembers(this);
		Model m = null;
		try {
			m = parseHelper.parse(r);
		} catch (Exception e) {
			e.printStackTrace();
		System.out.println("New run...");
		for  (XExpression decl : m.getExpressions()) {
			System.out.println(myInterpreter.evaluate(decl).getResult().toString());
		return null;
Previous Topic:Error with ParseHelper in Test xbase compiler
Next Topic:JavaIoFileSystemAccess - null pointer
Current Time: Sat Jul 26 10:30:03 EDT 2025
Powered by FUDForum. Page generated in 0.30091 seconds
