Home » Language IDEs » C / C++ IDE (CDT) » [Solved] Linux Kernel module build "make modules" error(error: "doesn't match the target pattern" in Linux module build)
[Solved] Linux Kernel module build "make modules" error [message #1052951] Wed, 01 May 2013 10:26 Go to next message
Hi all,
I am using Eclipse Juno, Ubuntu OS 64bit. I try to build Linux modules in Eclipse for ARM platform. Compiler: Sourcery CodeBench for ARM. Eclipse for ARM plug-in installed.
When I run make commands in terminal with root permission, then everything goes on OK.
But when I try build in Eclipse, the make target: "make uImage" is successful but "make modules" and "make modules_install" failed. Below is error i got when I run "make modules". I tried to run Eclipse in root permission (in terminal run: sudo ./eclipse) but error still happens. What went wrong here ?. Thanks
make -j2 modules
CHK include/generated/uapi/linux/version.h
CHK include/generated/utsrelease.h
make[1]: `include/generated/mach-types.h' is up to date.
CC scripts/mod/devicetable-offsets.s
CALL scripts/checksyscalls.sh
GEN scripts/mod/devicetable-offsets.h
HOSTCC scripts/mod/file2alias.o
HOSTLD scripts/mod/modpost
Building modules, stage 2.
MODPOST 11 modules
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/acenic/tg1.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/acenic/tg2.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/adaptec/starfire_rx.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/adaptec/starfire_tx.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/dsp56k/bootstrap.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/atmsar11.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/bnx2x/bnx2x-e1-6.2.9.0.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/bnx2x/bnx2x-e1h-6.2.9.0.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/bnx2x/bnx2x-e2-6.2.9.0.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/bnx2/bnx2-mips-09-6.2.1a.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/bnx2/bnx2-rv2p-09-6.0.17.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/bnx2/bnx2-rv2p-09ax-6.0.17.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/bnx2/bnx2-mips-06-6.2.1.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/bnx2/bnx2-rv2p-06-6.0.15.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/sun/cassini.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cxgb3/t3b_psram-1.1.0.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cxgb3/t3c_psram-1.1.0.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cxgb3/ael2005_opt_edc.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cxgb3/ael2005_twx_edc.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cxgb3/ael2020_twx_edc.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/matrox/g200_warp.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/matrox/g400_warp.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/r128/r128_cce.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/R100_cp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/R200_cp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/R300_cp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/R420_cp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RS690_cp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RS600_cp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/R520_cp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/R600_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/R600_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV610_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV610_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV630_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV630_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV620_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV620_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV635_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV635_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV670_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV670_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RS780_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RS780_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV770_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV770_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV730_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV730_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV710_pfp.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/radeon/RV710_me.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/av7110/bootcode.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/ttusb-budget/dspbootcode.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/e100/d101m_ucode.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/e100/d101s_ucode.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/e100/d102e_ucode.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/myricom/lanai.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/LA-PCM.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/PCMLM28.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/DP83903.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/NE2K.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/tamarack.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/PE-200.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/PE520.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/3CXEM556.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/3CCFEM556.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/MT5634ZLX.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/RS-COM-2P.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/COMpad2.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/COMpad4.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/SW_555_SER.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/SW_7xx_SER.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cis/SW_8xx_SER.cis' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/ositech/Xilinx7OD.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/advansys/mcode.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/advansys/38C1600.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/advansys/3550.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/advansys/38C0800.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/qlogic/1040.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/qlogic/1280.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/qlogic/12160.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/qlogic/isp1000.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/qlogic/sd7220.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/korg/k1212.dsp' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/ess/maestro3_assp_kernel.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/ess/maestro3_assp_minisrc.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/sb16/mulaw_main.csp' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/sb16/alaw_main.csp' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/sb16/ima_adpcm_init.csp' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/sb16/ima_adpcm_playback.csp' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/sb16/ima_adpcm_capture.csp' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/yamaha/ds1_ctrl.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/yamaha/ds1_dsp.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/yamaha/ds1e_ctrl.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/yamaha/yss225_registers.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/tehuti/bdx.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/tigon/tg3.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/tigon/tg3_tso.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/tigon/tg3_tso5.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/3com/typhoon.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/emi26/loader.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/emi26/firmware.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/emi26/bitstream.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/emi62/loader.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/emi62/bitstream.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/emi62/spdif.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/emi62/midi.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/kaweth/new_code.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/kaweth/trigger_code.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/kaweth/new_code_fix.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/kaweth/trigger_code_fix.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/mpr.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa18x.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa19.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa19qi.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa19qw.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa19w.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa28.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa28xa.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa28xb.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa28x.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa49w.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan/usa49wlc.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/ti_3410.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/ti_5052.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/mts_cdma.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/mts_gsm.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/mts_edge.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/edgeport/boot.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/edgeport/boot2.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/edgeport/down.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/edgeport/down2.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/edgeport/down3.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/whiteheat_loader.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/whiteheat.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan_pda/keyspan_pda.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/keyspan_pda/xircom_pgs.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/vicam/firmware.fw' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/cpia2/stv0672_vp4.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/yam/1200.bin' doesn't match the target pattern
/home/thangle/git/linux-stable/scripts/Makefile.fwinst:45: target `/home/thangle/modules_install/lib/firmware/yam/9600.bin' doesn't match the target pattern
22:19:53 Build Finished (took 52s.845ms)
[Updated on: Sat, 04 May 2013 05:05] by Moderator
Re: Linux Kernel module build "make modules" error [message #1053347 is a reply to message #1052951] Sat, 04 May 2013 05:04 Go to previous messageGo to next message
After turning on verbose mode, I found out problem. In Eclipse I set a env variable is INSTALL_MOD_PATH=~/modules_install.
In Terminal, ~/modules_install will be translated to: /home/thangle/modules_install
But in Eclipse, when compiling, It's still ~/modules_install which leaded to "doesn't match the target pattern" error.
Now, in Eclipse configuration, I changed value to: INSTALL_MOD_PATH=${HOME}/modules_install.
It works fine now.
My expectation is to do everything in a GUI environment instead of remembering/re-typing the command lines in terminal Smile.
[Updated on: Sat, 04 May 2013 11:30] by Moderator
Re: Linux Kernel module build "make modules" error [message #1698048 is a reply to message #1053347] Wed, 10 June 2015 11:38 Go to previous message
Hello
could you please advice me how to build kernel modules in Eclipse, we i did try to create a makefile and module and import it as makefile project in eclipse, but I have an excisting c++ project some of the files i wanted it to be built as modules and install in arm, arm=raspberry pi ..
I have explained my problem in the forum : in raspberry pi
www.raspberrypi.org /forums/viewtopic.php?f=63&t=112892
Previous Topic:CDT clean in makefile not working
Next Topic:Linux Project Builds but won't run.
Current Time: Sat Jul 26 11:43:19 EDT 2025
Powered by FUDForum. Page generated in 0.03564 seconds
