Home » Archived » EPF » RMC - publish HTML through command line help(RMC - publish HTML through command line help)
RMC - publish HTML through command line help [message #1021552] Wed, 20 March 2013 06:01 Go to next message
I am new in RMC and working on the publishing HTML through command line without starting the RMC application.
I got the few example over the eclipse help and forums but it is not working.
Like..
rmc.exe -rmcsilent publish -rmclibrary C:\Program Files\IBM\RMC\rmc\lib.7.5.prac -rmcconfiguration publish.practices_for_agile_development-ibm -rmcoutput C:\temp\rmcpub
I am not getting rmc.exe file under the rmc folder under rmc installation directory.
Is this same a eclipse.exe under rmc installation directory ?
whenever i am executing above command it is first opening the rmc application and after that nothing is happening.
so pls help me to resolve the above issue.
Inder
Re: RMC - publish HTML through command line help [message #1021679 is a reply to message #1021552] Wed, 20 March 2013 09:58 Go to previous messageGo to next message
It looks okay to me aside from the library path which has spaces. I don't think that will work. You need to put it between quotes.
rmc.exe -rmcsilent publish -rmclibrary "C:\Program Files\IBM\RMC\rmc\lib.7.5.prac" -rmcconfiguration publish.practices_for_agile_development-ibm -rmcoutput C:\temp\rmcpub
Re: RMC - publish HTML through command line help [message #1021807 is a reply to message #1021679] Wed, 20 March 2013 14:05 Go to previous messageGo to next message
Thank you so much Onno for the quick reply..
I asked one more thing regarding rmc.exe
When i installed RMC and then checked in the IBM->RMC75->rmc directory
I did not get the rmc.exe file in above directory.
Is rmc.exe is the same eclipse.exe resides in IBM->RMC75 directory or i did wrong while installation RMC ?
Because while publishing HTML from command line rmc.exe is required.
Inder
Re: RMC - publish HTML through command line help [message #1053234 is a reply to message #1021807] Fri, 03 May 2013 05:52 Go to previous messageGo to next message
Solved issues.. installing eclipse rmc 32 bit version.
Re: RMC - publish HTML through command line help [message #1065094 is a reply to message #1053234] Mon, 24 June 2013 06:55 Go to previous messageGo to next message
Could you tell us how you resolved it?
SWT Issue [message #1065131 is a reply to message #1065094] Mon, 24 June 2013 09:14 Go to previous message
I am trying to update Table data in SWT,like if the status is getting updated from Online to Offline in particular column the status should get changed,and table must be updated with recent data.
Please help me how can i achieve this.
Previous Topic:Visually appealing diagrams
Next Topic:Procedure to create EPF xml
Current Time: Wed Nov 05 14:56:15 EST 2025
Powered by FUDForum. Page generated in 0.03976 seconds
