Home » Modeling » TMF (Xtext) » default value for INT parameter(default value for INT parameter)
default value for INT parameter [message #1053162] Thu, 02 May 2013 14:59 Go to next message
Is it possible, in the grammar, to define a default value for an parameter ?
The thing is ok for ENUM as the first value is proposed.
But, basically with an integer parameter definition as the following:
Test:'Test' param=INT;
upon content assist, I would like to have a proposal with a given value (lets say 36 for example). Basically, the proposale is "param".
And what about ID default value, the same way ?
thanks.
Re: default value for INT parameter [message #1053177 is a reply to message #1053162] Thu, 02 May 2013 16:59 Go to previous messageGo to next message
simply customizing yourdslproposlprovider doesnt work?
Re: default value for INT parameter [message #1053178 is a reply to message #1053177] Thu, 02 May 2013 17:24 Go to previous messageGo to next message
class MyDslProposalProvider extends AbstractMyDslProposalProvider {
override completeTest_Param(EObject model, Assignment assignment, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
acceptor.accept(createCompletionProposal("42", context));
Re: default value for INT parameter [message #1053205 is a reply to message #1053178] Fri, 03 May 2013 02:32 Go to previous message
I thought there perhaps something could have been specified in the xtext file.
If not, ok, I will customize the proposal provider.
Thanks.
Previous Topic:Xtext with ATL
Next Topic:Refactoring breaks Scoping
Current Time: Wed Jul 23 21:38:58 EDT 2025
Powered by FUDForum. Page generated in 0.25392 seconds
