Home » Archived » BIRT » BIRT report with chinese titles in chart(Its squares instead of chinese inside the chart object)
BIRT report with chinese titles in chart [message #1053118] Thu, 02 May 2013 10:20 Go to next message
I have a few BIRT reports who is localized for both English and Chinese.
Everything looks fine except for the part inside the chart object, here its just squares instead of Chinese text.
I have searched around and found that some people had this problem but I never found any solution.
My question is: Is there anyone who know the exact solution how to display Chinese text for the X and Y Axis-title?
/Max
Re: BIRT report with chinese titles in chart [message #1053196 is a reply to message #1053118] Fri, 03 May 2013 01:20 Go to previous messageGo to next message
What's your BIRT version? I don't see the same issue in the version I tried it in.
Re: BIRT report with chinese titles in chart [message #1286991 is a reply to message #1053118] Mon, 07 April 2014 05:18 Go to previous messageGo to next message
Same problem here with Birt Version: Kepler Service Release 2
Build id: 20140224-0627
Inside Charts only squares, no valid chinese characters are shown.
thanks
Re: BIRT report with chinese titles in chart [message #1287035 is a reply to message #1053118] Mon, 07 April 2014 06:15 Go to previous messageGo to next message
I am using BIRT 2.6.1 for the purposes of this project.
We are moving to version 4.3.1 over the coming months. Michael, is 4.3 the version that it works in Michael ?
Anthony.
Re: BIRT report with chinese titles in chart [message #1287036 is a reply to message #1286991] Mon, 07 April 2014 06:20 Go to previous messageGo to next message
Ensure you are using the right font family, a font family that support Chinese characters, BIRT seems to recommend a setting of "all-fonts" as the font family.
There should be a way via configuration to map a font name to a font family to avoid hard coding the name "all-fonts" in your rptdesign files, but this you will have to find out. Let us know if you do.
Re: BIRT report with chinese titles in chart [message #1288800 is a reply to message #1287036] Tue, 08 April 2014 17:52 Go to previous message
Anthony, yeah, I believe I tried it in 4.3.2. It could have been 4.3.1 though.
Previous Topic:Via scripting - change Pie chart legend position from left to right
Next Topic:Birt PHP Java bridge not working with database driven reports
Current Time: Sat Jul 26 20:33:00 EDT 2025
Powered by FUDForum. Page generated in 0.02761 seconds
