Re: Group data on same line as detail data - How to? [message #1053237 is a reply to message #1053194] |
Fri, 03 May 2013 06:13   |
Michael,
Thank you very much for the idea and response but I can find a drop property setting on the General tab. On the General tab I see: Name, Element ID, Font, Size, Color, Background Color, Whitespace, Style, and Display. I checked out the other property tabs and didn't see it there either.
Marc
Re: Group data on same line as detail data - How to? [message #1053240 is a reply to message #1053194] |
Fri, 03 May 2013 06:26  |
OK, I played around some more and found the drop property. I had clicked in the wrong cell. The problem now though is that the drop property is only available in cells in which I don't have a value defined. When I set the property to detail in certain cells it drops the value displayed in that column.
FUDForum. Page generated in 0.06954 seconds
