Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] AGR hangs when widgetReg.xml contains an error
[AGR] AGR hangs when widgetReg.xml contains an error [message #105246] Tue, 17 July 2007 09:37 Go to next message
Hello.
I think the following is a bug: when I add a rule to the widgetReg.xml
file that results in an error during playback, AGR hangs during
execution and the process needs to be killed from the outside. I think
the behaviour should be gentler, especially since the hard interruption
of the playback results in no reporting of the problem at any level
(either in log files or in .execution files).
Is this indeed a bug? Should I enter it in Bugzilla?
TIA,
B.
Re: [AGR] AGR hangs when widgetReg.xml contains an error [message #105302 is a reply to message #105246] Tue, 17 July 2007 12:16 Go to previous message
Hi Barbara,
I would agree that this behaviour is confusing and that the AGR should
report an error clearly when it occurs as a result of a problem in the
resolver. Please open a defect in Bugzilla.
Sincerely,
Liz Dancy
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:f7iglu$j58$3@build.eclipse.org...
> Hello.
> file that results in an error during playback, AGR hangs during execution
> and the process needs to be killed from the outside. I think the behaviour
> should be gentler, especially since the hard interruption of the playback
> results in no reporting of the problem at any level (either in log files
> TIA,
> B.
Previous Topic:[AGR] widgetReg.xml not read dynamically
Next Topic:jni calls from a c++ tptp agent crashes vm
Current Time: Wed Jul 23 05:23:00 EDT 2025
Powered by FUDForum. Page generated in 1.06683 seconds
