Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] Issue with FeatureId's
[Texo] Issue with FeatureId's [message #1052507] Tue, 30 April 2013 03:09 Go to next message
Hi Martin,
first, thanks for the great tool.
but at the moment I have a problem with the the conversion from pojo's
to EMF model objects.
All my classes extends one abstract object and also implements one or
more defined interfaces.
The generation and my object looks good, but on converting the object, i
got message based on wrong feature id's.
Thats my simple test code and I attach my model into this message.
LibraryModelPackage.initialize();
ResourceSet rs = new ResourceSetImpl();
rs.getResourceFactoryRegistry().getExtensionToFactoryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XMIResourceFactoryImpl());
URI fileUri = URI.createFileURI("D:/Library.xmi");
Resource resource = rs.createResource(fileUri);
Library l = new Library();
l.setName("Library");
List<Object> objects = new ArrayList<Object>();
objects.add(l);
Writer w = new Writer();
w.setFirstName("FirstName");
w.setLastName("LastName");
l.addToWriters(w);
Publisher p = new Publisher();
p.setCompany("Company");
l.addToPublishers(p);
Book b = new Book();
b.setTitle("Book");
l.addToBooks(b);
ModelEMFConverter m2eConverter= new ModelEMFConverter();
List<EObject> eObjects = m2eConverter.convert(objects);
If I do run these code I've got:
Exception in thread "main" java.lang.IllegalArgumentException:
EStructuralFeature: org.eclipse.emf.ecore.impl.EAttributeImpl@46f93
(name: id) (ordered: true, unique: true, lowerBound: 0, upperBound: 1)
(changeable: true, volatile: false, transient: false,
defaultValueLiteral: null, unsettable: false, derived: false) (iD:
false) not found in EClass org.eclipse.emf.ecore.impl.EClassImpl@1dbc144
(name: Writer) (instanceClassName: null) (abstract: false, interface: false)
at
org.eclipse.emf.texo.model.AbstractModelObject.eGet(AbstractModelObject.java:59)
at
library.LibraryModelFactory$CommonLibraryObjectModelObject.eGet(LibraryModelFactory.java:358)
at
library.LibraryModelFactory$WriterModelObject.eGet(LibraryModelFactory.java:447)
at
org.eclipse.emf.texo.converter.ModelEMFConverter.convertSingleEAttribute(ModelEMFConverter.java:407)
at
org.eclipse.emf.texo.converter.ModelEMFConverter.convertContent(ModelEMFConverter.java:183)
at
org.eclipse.emf.texo.converter.ModelEMFConverter.convert(ModelEMFConverter.java:104)
at tests.library.Test.main(Test.java:55)
It seems that the the attribute "id" has diffrent feature id's and so it
was not found on conversion.
Is it a bug or a desing error??
Greetings
Heiko
Re: [Texo] Issue with FeatureId's [message #1052900 is a reply to message #1052507] Wed, 01 May 2013 03:18 Go to previous messageGo to next message
Hi Heiko,
I need to test myself, I hope to do that within a day. One question, did you also generate EMF code from this same
model? You debugged and indeed the featureid of the id efeature is not inline with what is expected? Or is the id
efeature not present in the eclass even?
gr. Martin
On 04/30/2013 09:09 AM, Heiko wrote:
> Hi Martin,
> but at the moment I have a problem with the the conversion from pojo's to EMF model objects.
> All my classes extends one abstract object and also implements one or more defined interfaces.
> The generation and my object looks good, but on converting the object, i got message based on wrong feature id's.
> rs.getResourceFactoryRegistry().getExtensionToFactoryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION, new
> objects.add(l);
> l.addToWriters(w);
> b.setTitle("Book");
> l.addToBooks(b);
> Exception in thread "main" java.lang.IllegalArgumentException: EStructuralFeature:
> org.eclipse.emf.ecore.impl.EAttributeImpl@46f93 (name: id) (ordered: true, unique: true, lowerBound: 0, upperBound: 1)
> (changeable: true, volatile: false, transient: false, defaultValueLiteral: null, unsettable: false, derived: false) (iD:
> false) not found in EClass org.eclipse.emf.ecore.impl.EClassImpl@1dbc144 (name: Writer) (instanceClassName: null)
> at org.eclipse.emf.texo.model.AbstractModelObject.eGet(AbstractModelObject.java:59)
> at library.LibraryModelFactory$CommonLibraryObjectModelObject.eGet(LibraryModelFactory.java:358)
> at library.LibraryModelFactory$WriterModelObject.eGet(LibraryModelFactory.java:447)
> at org.eclipse.emf.texo.converter.ModelEMFConverter.convertSingleEAttribute(ModelEMFConverter.java:407)
> at org.eclipse.emf.texo.converter.ModelEMFConverter.convertContent(ModelEMFConverter.java:183)
> at org.eclipse.emf.texo.converter.ModelEMFConverter.convert(ModelEMFConverter.java:104)
> It seems that the the attribute "id" has diffrent feature id's and so it was not found on conversion.
> Greetings
> Heiko
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] Issue with FeatureId's [message #1053222 is a reply to message #1052900] Fri, 03 May 2013 04:37 Go to previous messageGo to next message
Hi Martin,
I do generate only Texo code (including the model package /factory
files) from this model.
After some more test, I found that there is a problem if my abstract
supertype is not on the first position of supertypes.
Here my little test result:
EClass: CommonLibraryObject, EAttributeId: 0, Returned FeatureId from
EClass: 0
EClass: Library, EAttributeId: 0, Returned FeatureId from EClass: 0
EClass: Writer, EAttributeId: 0, Returned FeatureId from EClass: 0
EClass: Publisher, EAttributeId: 0, Returned FeatureId from EClass: 2
EClass: Book, EAttributeId: 0, Returned FeatureId from EClass: 0
On this test all classes have a the abstract class CommonLibraryObject
as supertype.
Writer and publisher have also an interface Person.
The diffrence are that writer has the CommonLibraryObject as first
supertype and publisher has the Person interface as first supertype.
So it seems that an abstract class should be everytime defined as first
supertype inside the ecore model.
As it is with multiple interfaces, I have to test it again later.
Greetings
Heiko
PS: If I have one or the other idea to Texo, should I post them here or
open a bug?
Am 01.05.2013 09:18, schrieb Martin Taal:
> Hi Heiko,
> you also generate EMF code from this same model? You debugged and indeed
> is the id efeature not present in the eclass even?
> gr. Martin
>> Hi Martin,
>> new
>> objects.add(l);
>> l.addToWriters(w);
>> b.setTitle("Book");
>> l.addToBooks(b);
>> EStructuralFeature:
>> at
>> at
>> at
>> at
>> at
>> at
>> Greetings
>> Heiko
Re: [Texo] Issue with FeatureId's [message #1053506 is a reply to message #1053222] Mon, 06 May 2013 06:36 Go to previous messageGo to next message
Hi Heiko,
After some debugging I think it is a bug/missing feature on how texo generates the feature ids in the
ModelPackage/ModelFactory code. I entered a bugzilla for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=407275
and pushed a solution, I am doing a new build. When that passes I will publish a solution.
gr. Martin
On 05/03/2013 10:37 AM, Heiko wrote:
> Hi Martin,
> I do generate only Texo code (including the model package /factory files) from this model.
> After some more test, I found that there is a problem if my abstract supertype is not on the first position of supertypes.
> EClass: CommonLibraryObject, EAttributeId: 0, Returned FeatureId from EClass: 0
> On this test all classes have a the abstract class CommonLibraryObject as supertype.
> The diffrence are that writer has the CommonLibraryObject as first supertype and publisher has the Person interface as
> first supertype.
> So it seems that an abstract class should be everytime defined as first supertype inside the ecore model.
> Greetings
> Heiko
> PS: If I have one or the other idea to Texo, should I post them here or open a bug?
>> Hi Heiko,
>> gr. Martin
>>> Hi Martin,
>>> new
>>> objects.add(l);
>>> l.addToWriters(w);
>>> b.setTitle("Book");
>>> l.addToBooks(b);
>>> EStructuralFeature:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Greetings
>>> Heiko
The Netherlands
Re: [Texo] Issue with FeatureId's [message #1053517 is a reply to message #1053222] Mon, 06 May 2013 07:08 Go to previous message
Hi Heiko,
I published a new build which should solve this.
gr. Martin
> Hi Martin,
> first supertype.
> Greetings
> Heiko
>> Hi Heiko,
>> gr. Martin
>>> Hi Martin,
>>> new
>>> objects.add(l);
>>> l.addToWriters(w);
>>> b.setTitle("Book");
>>> l.addToBooks(b);
>>> EStructuralFeature:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Greetings
>>> Heiko
The Netherlands
Previous Topic:[MWE2] Help executing mwe2 workflows from java
Next Topic:Epatch in current EMF Compare
Current Time: Sat Jul 26 02:08:03 EDT 2025
Powered by FUDForum. Page generated in 0.04915 seconds
