Home » Modeling » TMF (Xtext) » My generated .java file wont run while in the eclipse application
My generated .java file wont run while in the eclipse application [message #1052712] Tue, 30 April 2013 08:48 Go to next message
I have setup the xText example file statemachine, when I run the example as a new eclipse application and generate the .java file from it everything seems to go as expected.
however when I then try to run this file i get an error, 'editor does not have a main'
However if i copy and paste the generated java code into a new project it will run fine, how can I compile and run the code straight from the example without needing to manually copy + paste it into a new file?
Re: My generated .java file wont run while in the eclipse application [message #1052734 is a reply to message #1052712] Tue, 30 April 2013 09:13 Go to previous messageGo to next message
are you sure the file is in a source folder?
Re: My generated .java file wont run while in the eclipse application [message #1052741 is a reply to message #1052734] Tue, 30 April 2013 09:23 Go to previous messageGo to next message
Yeah, it's been created in the src-gen folder
Re: My generated .java file wont run while in the eclipse application [message #1052744 is a reply to message #1052741] Tue, 30 April 2013 09:25 Go to previous messageGo to next message
i mean is it a java source folder by means of eclipse
Re: My generated .java file wont run while in the eclipse application [message #1052798 is a reply to message #1052744] Tue, 30 April 2013 10:45 Go to previous messageGo to next message
BTW Can Xtext somehow create eclipse source folder automatically? For the first time i have do this always manually?
Re: My generated .java file wont run while in the eclipse application [message #1052811 is a reply to message #1052798] Tue, 30 April 2013 11:02 Go to previous message
Hmmm i guess you have to digg into jdt api for that.
Previous Topic:Repeated value in a grammar rule
Next Topic:Semantic modification via IUnitOfWork brakes grammar
Current Time: Fri Jul 25 16:50:07 EDT 2025
Powered by FUDForum. Page generated in 0.03601 seconds
