Re: Other/Custom names for Objects in EMF-Plugin [message #1863905 is a reply to message #1052718] |
Tue, 05 March 2024 04:35  |
Hey, i get this solution in 2024 fortunately.
And it's something that is currently in my use but some editing needed.
I want to rename one object label at the runtime as it's parameter name. But i also want to change the name of the other objects to the parameter name of this object that currently contains this object.
Let's say I have A and B class.
and every object of B class contains one object of Class A associated with it.
Now, If you provide the name to the object of A, then the label of A's object if getting changed that's good but i also want to change the name of the object of B who is associated with this A's object in any way.
Can i do that because it will automate my whole thing and UI will look more nicer and i will not have to do the linking with A's object.
Any help would be appreciated.
Thanks in advance.
FUDForum. Page generated in 0.19923 seconds
