Resolving proxy URIs with a customized URI schema [message #1052657] |
Tue, 30 April 2013 07:11  |
Hi everyone,
Sorry if a similar question has been asked elsewhere. We tried to look around in the news group for a proper solution to our problem, but did not find anything.
We have an EMF application based on interlinked XMI resources. These XMI resources are referenced to each other by proxy URIs with a customized URI schema provided by an external XMI repository. The protocol of this schema is "localref://". We have all the XMI resources stored locally in a file repository (not in the Eclipse project).
What we are trying to do is the load the correct referenced files specified by the proxy URI. We tried doing this by implementing our own URIHandler and connecting it to our ResourceSet like this:
editingDomain.getResourceSet().getURIConverter().getURIHandlers().add(0,new OurURIHandler(editingDomain.getResourceSet()));
When we click on a proxy URI in the editor, the proxy URI is being sent to the "createInputStream" method in the "OurURIHandler" class. We have no clue where to go from here, and we would highly appreciate any pointers or advices on how to proceed!
Thanks in advance!
Magnus Stuhr
Re: Resolving proxy URIs with a customized URI schema [message #1052821 is a reply to message #1052657] |
Tue, 30 April 2013 11:28   |
Magnus,
Comments below.
On 30/04/2013 2:47 PM, Magnus Stuhr wrote:
> Hi everyone,
> not find anything.
> project).
What do you mean by a file repository. Are they just files in the file
system?
Look at some of the other handlers like FileURIHandler and the base
class URIHandlerImpl. Before I try to give a detailed answer that
might not be relevant, I need to understand what you mean by a "file
repository".
> Thanks in advance!
> Best regards,
> Magnus Stuhr
Re: Resolving proxy URIs with a customized URI schema [message #1053087 is a reply to message #1053046] |
Thu, 02 May 2013 07:21  |
Magnus,
In that case it should suffice to use URI mappings in the URI
converter. Properly you can use a folder mapping for this type of
thing, i.e., foo:/bar/ -> file:/d:/folder/ would map all URIs starting
with the given prefix to the given location in the file system.
On 02/05/2013 10:04 AM, Magnus Stuhr wrote:
> Hi again,
> Sorry if I was a bit unclear. By "file repository" I mean we have all
> the relevant files stored locally on our file system. In other words,
> we have all the models stored locally as XMI.
FUDForum. Page generated in 0.03933 seconds
