Home » Modeling » EMF » [CDO] CDOServer throws "The object is already closed [90007-168]" errors with H2-DB
[CDO] CDOServer throws "The object is already closed [90007-168]" errors with H2-DB [message #1051466] Sun, 28 April 2013 17:06 Go to next message
From time to time my cdo server (4.2 latest nightly-build) throws following error, at this moment only restarting of the server helps.
It seems that this error have someting to do with conflicting transactions.
Up to now I'm wasn't able to reproduce this with an junit test. Perhaps someone has an idea what the problem could be, or at where to start debugging.
Best Regards
Stefan Schedl
!ENTRY org.eclipse.net4j 4 0 2013-04-28 21:01:42.212
!MESSAGE org.h2.jdbc.JdbcSQLException: The object is already closed
!STACK 0
org.eclipse.net4j.db.DBException: org.h2.jdbc.JdbcSQLException: The object is already closed
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.readValuesFromStatement(AbstractHorizontalClassMapping.java:345)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchingClassMapping.readRevision(HorizontalBranchingClassMapping.java:381)
at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.readRevision(DBStoreAccessor.java:251)
at org.eclipse.emf.cdo.internal.server.Repository.loadRevisions(Repository.java:485)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.loadRevisions(CDORevisionManagerImpl.java:387)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisions(CDORevisionManagerImpl.java:292)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevision(CDORevisionManagerImpl.java:275)
at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.execute(RevisionInfo.java:133)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevisionsIndication.responding(LoadRevisionsIndication.java:169)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.responding(CDOServerIndication.java:133)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerReadIndication.execute(CDOServerReadIndication.java:36)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.h2.jdbc.JdbcSQLException: The object is already closed
at org.h2.message.DbException.getJdbcSQLException(DbException.java:329)
at org.h2.message.DbException.get(DbException.java:169)
at org.h2.message.DbException.get(DbException.java:146)
at org.h2.message.DbException.get(DbException.java:135)
at org.h2.jdbc.JdbcStatement.checkClosed(JdbcStatement.java:925)
at org.h2.jdbc.JdbcPreparedStatement.checkClosed(JdbcPreparedStatement.java:1523)
at org.h2.jdbc.JdbcStatement.checkClosed(JdbcStatement.java:901)
at org.h2.jdbc.JdbcStatement.setMaxRows(JdbcStatement.java:358)
at org.eclipse.net4j.internal.db.DBPreparedStatement.setMaxRows(DBPreparedStatement.java:194)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalClassMapping.readValuesFromStatement(AbstractHorizontalClassMapping.java:275)
... 18 more
Re: [CDO] CDOServer throws "The object is already closed [90007-168]" errors with [message #1051700 is a reply to message #1051466] Mon, 29 April 2013 02:03 Go to previous messageGo to next message
Hi Stefan,
This one is interesting because it seems that the problem has always been in HorizontalBranchingClassMapping.readRevision():
finally
statementCache.releasePreparedStatement(stmt);
readValuesFromStatement(stmt, revision, accessor);
In other words, the statement had been release to the pool but nevertheless been used thereafter. This could have
resulted in unpredictable behaviour everywhere. But recently there was this major overhaul of the DB framework:
401763: Make CDO Server more robust against data dictionary changes
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401763
So that the code now looks like this:
finally
DBUtil.close(stmt);
And the usage of statement leads to an immediate exception. Good, I can fix this now. Please submit a bugzilla.
Cheers
/Eike
http://www.esc-net.de
Am 28.04.2013 23:06, schrieb Stefan Schedl:
> the server helps. It seems that this error have someting to do with conflicting transactions.
> Best Regards
> Stefan Schedl
> !STACK 0
> at
> at
> at
> at
> ... 18 more
Re: [CDO] CDOServer throws "The object is already closed [90007-168]" errors with [message #1051778 is a reply to message #1051700] Mon, 29 April 2013 04:06 Go to previous message
Great, Yesterday I thought about to create the bug directly, but I thought the bug description would be to unspecified Smile
Bug is created: https://bugs.eclipse.org/bugs/show_bug.cgi?id=406766.
Thanks for the support
Stefan
Previous Topic:[CDO] Tables in DB without Primary Key
Next Topic:[Teneo] Dynamic EMF, References
Current Time: Fri Jul 18 18:24:01 EDT 2025
Powered by FUDForum. Page generated in 0.11447 seconds
