Home » Newcomers » Newcomers » pserver vs extssh
pserver vs extssh [message #103416] Tue, 20 September 2005 19:56 Go to next message
Originally posted by: jbailo.vestcom.com
I set up a cvs repository on my Suse 9.3 workstation.
I can connect to it from my Windows workstation, using Eclipse, using
extssh.
I can also connect to it with my Linux Eclipse locally ( localhost ) but
it doesn't let me use the pserver protocol.
Re: pserver vs extssh [message #103478 is a reply to message #103416] Wed, 21 September 2005 03:12 Go to previous messageGo to next message
Originally posted by: liden.carmen.se
"John Bailo" <jbailo@vestcom.com> skrev i meddelandet
news:dgq7k2$hov$1@news.eclipse.org...
> extssh.
Have you set up/configured the CVS password server?
I have a related question: Why is there no option for connecting to CVS
locally (without pserver)?
Due to this (and since pserver does not seem to work) I must use extssh
(despite being on the same network as CVS). That works from within Eclipse,
but I can't do manual CVS operations in the workspace (e.g. cvs update),
because it says:
cvs update: Unknown method (`extssh') in CVSROOT.
cvs [update aborted]: Bad CVSROOT:
`:extssh:liden@localhost:/carm/2_CVS'.
I can of course explicitly state the root (e.g. cvs -d /carm/2_CVS update)
but that is a nuisance. Any suggestions?
/Tomas
Re: pserver vs extssh [message #103494 is a reply to message #103478] Wed, 21 September 2005 03:56 Go to previous messageGo to next message
Originally posted by: ziya.ripe.net
Hi there,
Here is a workaround to use CVS locally on the file system:
1 Write a little shell script to simply invoke 'cvs server'
file: cvs_server.sh
#!/bin/sh
cvs server
2 Make sure your file is executable:
(E.g. 'chmod +x cvs_server.sh')
3 In Eclipse go to:
Widows>Preferences>Team>CVS>Ext Connection Method
Enter full path of your script
(E.g. '/home/ziya/bin/cvs_server.sh')
You are ready to go! While adding a new CVS repository in
Eclipse make sure to choose:
1 Connection type 'ext'
2 Enter your repository path correctly (E.g. '/var/cvsroot')
and fill other mandatory fields with anything!
Hope it works for you too.
--Ziya
>>extssh.
> because it says:
> /Tomas
Re: pserver vs extssh [message #103512 is a reply to message #103494] Wed, 21 September 2005 05:48 Go to previous messageGo to next message
Thanks for the tip - that would work from within Eclipse.
But I guess Eclipse will still create something like
":ext:user@host:/cvs_repository" in all CVS/Root files, which is the cause
of my trouble. I would like Eclipse to have a local option that simply
creates "/cvs_repository" in the CVS/Root files.
/Tomas
"Ziya Suzen" <ziya@ripe.net> skrev i meddelandet
news:dgr3nn$iig$1@news.eclipse.org...
> Hi there,
> file: cvs_server.sh
> #!/bin/sh
> cvs server
> 3 In Eclipse go to:
> Cheers,
> --Ziya
> Tomas Lid
Re: pserver vs extssh [message #105140 is a reply to message #103512] Tue, 27 September 2005 03:38 Go to previous messageGo to next message
Yes. You are right! I tried to set CVSROOT etc. but couldn't get around
that!
--Ziya
> /Tomas
>>Hi there,
>> file: cvs_server.sh
>> #!/bin/sh
>> cvs server
>>3 In Eclipse go to:
>>Cheers,
>>--Ziya
>>>>extssh.
> Eclipse,
>>>because it says:
> update)
>>>/Tomas
Re: pserver vs extssh [message #105198 is a reply to message #105140] Tue, 27 September 2005 05:17 Go to previous messageGo to next message
news:dhassq$g9j$1@news.eclipse.org...
> Tomas Lid
Re: pserver vs extssh [message #113482 is a reply to message #105198] Tue, 01 November 2005 02:39 Go to previous message
"Tomas Lid
Previous Topic:Java Method Recognition
Next Topic:'Ctrl-C' in a console
Current Time: Fri Nov 07 08:10:33 EST 2025
Powered by FUDForum. Page generated in 0.08615 seconds
